CEL ON more than OFF!
Posted: Tue Oct 11, 2005 10:09 am
by Vibedad
Have a Cosmo on my 05 Base that has worked great with only a few problems in 6 months. Now, about every other day, my CEL is ON! A quick check with the dealer found it to be related to air flow so I know it's my CAI. I have checked all the connections as well as the filter and all seems OK. When I reset, I let the car idle for at least 15 minutes.Has anyone else experienced this?Where should I look or what should I do?
Re: CEL ON more than OFF! (Vibedad)
Posted: Wed Oct 12, 2005 10:53 am
by Lancer
What type of air flow problem?Check to make sure that the MAF is on correctly and not backwards.Clean the air filter.Clean the MAF sensor.If you still have a CEL on, put the stock air box in for a while and see if it comes back. Good luck!
Posted: Wed Oct 12, 2005 11:29 pm
by zionzr2
something to try:1. disconect battery overnight2. reconnect battery 3. start car and let idle for 5-10 minutes
Re: (zionzr2)
Posted: Thu Oct 13, 2005 12:08 am
by Vibedad
Will the long battery disconnect make a difference? I just don't know what effect this would have.
Re: (Vibedad)
Posted: Thu Oct 13, 2005 12:16 am
by Vibedad
Checked my paperwork from the Dealer. Code set was PO171 - diagnose cause of lean condition.Codes cleared and retested 5% @ idle
Re: (Vibedad)
Posted: Thu Oct 13, 2005 8:20 am
by Lancer
You only need to disconnect the battery for about 15-20 minutes to completley clear the CEL. But it's easy to do and there's no harm in leaving it off overnight.I doubt that just a CAI would be the cause of a lean condition bad enough to throw a CEL. Try some fuel injector cleaner and run some higher octain gas through your system and see if that helps.
Posted: Thu Oct 13, 2005 11:28 am
by goodvibe
Did you oil the cosmo filter as recommended? You may have oil on the MAF. It won't need much with the CAI that already runs a bit lean. Reset when finished and cross fingers.
Re: (goodvibe)
Posted: Thu Oct 13, 2005 11:48 am
by Vibedad
Oiled when first installed which was back in May, so I doubt that would be the problem now. I will try some injection cleaner to see if it helps. I also noticed that the hose that runs from under the plastic engine cover into the CAI had a very tight bend in it. I am wondering if it was crimping so I have rerouted it. Do not know if that would have caused this problem though. What is that hose for?
