Checking the oil on the base vibe?
Posted: Sat Dec 21, 2002 4:48 am
by E-Man
Question for when checking the oil on the base vibe. The oil should be between the two dots on the dipstick? That is what I think -- but in reading over the owners manual I did not think it is stated. How do you guys look at it?Ed
Re: Checking the oil on the base vibe? (E-Man)
Posted: Sat Dec 21, 2002 5:00 am
by NSimkins
My oil level (base engine) is always at or very near the top mark on the dipstick.The owners manual (located here), 6-14 through 6-16, states that if the oil level is below the lower mark that you may need to add at least 1 quart of oil.
Posted: Sat Dec 21, 2002 6:54 am
by NovaResource
The top dot is full. The lower dot is 1 qt low. It should be at the top dot but as long as it's inbetween the 2, it's ok. If it drops to the lower dot, add a quart.
