torque #'s
Posted: Sun Oct 02, 2005 8:44 am
by Vibe_dude
can anyone tell what are the right torque #'s for the steel and alumium rims.......i ahve both just not sure what to torque them to.thkz
Re: torque #'s (Vibe_dude)
Posted: Sun Oct 02, 2005 9:47 am
by cohocarl
If I remember right, the manual said 76ft/lbs.
Re: torque #'s (cohocarl)
Posted: Sun Oct 02, 2005 12:14 pm
by binary
Quote, originally posted by cohocarl »If I remember right, the manual said 76ft/lbs.Open your cargo floor - it's printed in English and French on stickers stuck to the black plastic spare organizer.I remember seeing them there this afternoon while detailing my car - but now it's raining outside, you go look.
Posted: Mon Oct 03, 2005 9:26 pm
by Vibe_dude
cool thanks guys.
Re: (Vibe_dude)
Posted: Mon Oct 17, 2005 8:34 am
by jasonvibe
I suggest getting a second set of lug nuts. The aluminum wheel lug nuts have washers. They have a tapered end to hold your steel spare. But I would not run the originals all winter w/ steel rims. I have to get a set myself. I have seen them for $30 to secure all 4 wheels. Nut size 12mm x 1.25...per my dealer. BUT I HAVE JUST CONFIRMED THE NUT SIZE IS 12 x 1.5 as most already know.
Re: (jasonvibe)
Posted: Mon Oct 17, 2005 12:56 pm
by Altus
Uh - pretty sure that should be M12 x 1.5 - no? Can't find my thread guage, but I'm pretty sure they're 1.5 pitch....
Re: (Altus)
Posted: Tue Oct 18, 2005 11:07 am
by jasonvibe
when my dealer ordered the rims @ cost, he looked up the lug nuts. Showed me on the computer 12 x 1.25...But they were about $5 each from the dealer at his cost. I have a nut off an old Jap truck that happens to fit the Vibe. I'll go to the auto store and see where it threads onto their sizing display. ...UPDATE: the thread size is 12 x 1.5 . Dealer was wrong.
Re: torque #'s (binary)
Posted: Wed Oct 19, 2005 12:02 pm
by Vibe_dude
Quote, originally posted by binary »Open your cargo floor - it's printed in English and French on stickers stuck to the black plastic spare organizer.I remember seeing them there this afternoon while detailing my car - but now it's raining outside, you go look. the numbers printed there are for the torque of the spare wheel......iam guessing that it must be 100 foot pounds...that is what my 99 z24 was.and it had the same size wheel.205/55/16.
Posted: Sun Oct 23, 2005 9:11 am
by jasonvibe
NO! 76 ft.-lbs is for all wheels. I have been acustom to 100 ft-lbs for cars lug nuts also. But these nuts are tightly spaced. So 100 is not needed or the 12mm threads can't take 100 ft-lbs.
Torque #'s
Posted: Sun May 20, 2007 8:22 am
by Vibe_dude
So I am about to do a brake job.can anyone tell what the torque # for the calipers are...i know that the rims are 76lbs.but need to make sure everything is put back on right.
Re: Torque #'s (Vibe_dude)
Posted: Sun May 20, 2007 9:02 am
by kevera
ah...Till there tight.I don't go by #'s,just real tight.
Posted: Sun May 20, 2007 2:00 pm
by trimovingxr
looks like front caliper bolts = 25 ft.lbs.http://www.illformedpragma.com...n.pdf
Posted: Fri May 25, 2007 2:11 am
by Sublimewind
Make sure you don't lube any of the bolts you are torquing... Seriously, it changes the spec by reducing friction and can change DRASTICLY... like say for instance 25ftlbs without lube to 75+ftlbs WITH lube... Just a quick tip...
