Are tires covered under warranty?
Posted: Thu Sep 29, 2005 10:48 pm
by vibe-04
I woke up this morning and backed out of the garage and had a feeling something wasn't right. Put it into first and drove 5 feet and yep, somethings wrong. Stopped and my driver's side rear was flat. So I parked it and took the truck (having a backup vehicle priceless).I can't see a nail and there is no sidewall puncture marks. I'm not sure of the valve stem. I don't think it was a slow leak cause I would have noticed. I've got about 10,000 KM on the Contis and just want to know anyones experience with having the tire covered under warranty?Andrew
Posted: Fri Sep 30, 2005 2:41 am
Tires are NEVER covered under warranty unless they clearly fail for a defect in manufacturing, or if you pay for road hazard protection.
Re: (ragingfish)
Posted: Fri Sep 30, 2005 3:06 am
or, perhaps abnormal wear if the failure of some warranteed part caused the tire problem
Re: Are tires covered under warranty? (vibe-04)
by bud_one
I had the same problem with my Goodyears....one would loose air...no pucture or anything....- changed out the valve stem with a new one andthe problem went away...
Posted: Sat Oct 01, 2005 5:57 am
by vibe-04
Drywall screw: $20 fix and I'm back on the road. Thanks for all you input.Andrew
