Front & rear disc removal
Posted: Wed Sep 28, 2005 8:24 am
by Pawel
I'm planning on removing the front and rear disc to service my brakes. does anyone ever tried this? My mechanic told me that it is "pain in the (removed)"... I just want to know if i should do it myself or go to shop.
Re: Front & rear disc removal (Pawel)
Posted: Wed Sep 28, 2005 10:02 am
by scherry2
I just took my front calipers off to paint them. it was quite easy only a couple of bolts on the back of the calipers and the bolt(s) that holds the caliper to the hub assembly.
Re: Front & rear disc removal (scherry2)
Posted: Wed Sep 28, 2005 11:33 am
by Pawel
do i have to punch out the bolts to remove the disc from the hub assembly?
Posted: Wed Sep 28, 2005 11:40 am
It looks like once you move the caliper out of the way, the disk will just come off the hub, should slide over the lug studs.
