Security System Question
Posted: Tue Jun 18, 2002 11:41 pm
by MJN2
I'm having trouble finding the appropriate info for this, so I'll ask here.My insurance company requires I fill out a form to get a discount for having a security system on my Vibe, but I can't find what the security system consists of. The questions I need answered are:1. Is there a fuel, ignition, or starter cut-off?2. Is there a steel/metal collar protecting the steering column?3. Is the security system enabled after the key is removed from the ignition, or only after the doors are locked with the remote?Any info would be greatly appreciated. Thanks
Re: Security System Question (MJN2)
Posted: Tue Jun 18, 2002 11:55 pm
by lopers
1. Theft-protection system: full-function alarm includes motion sensor, glass breakage sensor, and fuel system shut-off.2. That sounds like a 'Club' or some other kind of lockable steering wheel device.3. The system will arm in about 10-15 seconds when you lock the car with the remote or if you manually lock the car from the door and then close it.
Posted: Tue Jun 18, 2002 11:59 pm
by NSimkins
I believe...2. You are correct and in addition it is an aftermarket addition that is installed on the steering column and is always there. It is to prevent access to the mechanicals in that area. Basically like a sheath.Updated: Prevent thieves from breaking into the steering column to "hotwire" vehicles; some are installed permanently and others must be installed manually each time the driver leaves the vehicle.
[Modified by NSimkins, 11:14 AM 6/19/2002]
Re: Security System Question (NSimkins)
Posted: Wed Jun 19, 2002 12:13 am
by MJN2
Thanks for the replies.Now I just have to remind my insurance agent about the side airbags
Posted: Wed Jun 19, 2002 5:24 am
by d_m_kolb
This post should be in Audio and Electronics not the Vibe Lounge.
Re: Security System Question (lopers)
Posted: Tue Nov 19, 2002 3:05 am
by esjones
quote:1. Theft-protection system: full-function alarm includes motion sensor, glass breakage sensor, and fuel system shut-off.2. That sounds like a 'Club' or some other kind of lockable steering wheel device.3. The system will arm in about 10-15 seconds when you lock the car with the remote or if you manually lock the car from the door and then close it.Where did you get this information about the security system having such items as listed in #1? I didn't see that in the Owner's manual.Thanks! - Earl
Re: Security System Question (esjones)
Posted: Tue Nov 19, 2002 3:12 am
by NovaResource
quote:Where did you get this information about the security system having such items as listed in #1?It's on the Pontiac Vibe web page under "Interior features":http://www.pontiac.com/pontiacjsp/vibe/ ... ource=lnav
