question about superchargers?
Posted: Sun Sep 11, 2005 11:08 pm
by heha
say I buy a super charger(say from a matrix), would I also need a intercooler? just a question.what about a new clutch?I really want to get one...
Re: question about superchargers? (heha)
Posted: Sun Sep 11, 2005 11:25 pm
by BlueCrush
You don't need an intercooler. The S/C ECU runs the S/C at 7.5psi with nothing else. If you use an aftermarket ECU and run it no higher than 7.5psi then you shouldn't need anything else. If you go with an aftermarket ECU and you run higher psi, you will need to either have it custom tuned to allow more fuel(and possibly upgrade the fuel pump and fuel injectors), install a water/methanol injection(W/I) system or use an intercooler of some sort. I don't believe tha anyone is using an intercooler with the S/C yet. Most people opt for the W/I because it is a lot less expensive.Edit: Oh, yeah. You will fry your stock clutch in no time.
Posted: Mon Sep 12, 2005 8:25 am
by heha
so i dont need anuthing else? just the charger and Im good to go... i like that
Re: (heha)
Posted: Mon Sep 12, 2005 8:54 am
by BlueCrush
Quote, originally posted by heha »so i dont need anuthing else? just the charger and Im good to go... i like thatAnd a S/C ECU.
Posted: Mon Sep 12, 2005 11:44 am
by heha
im sorry, i thought it meant that s/c came with a chip. So I need to get one of these as well eh? would i get one of these from a dealer or just from a local car shop?again sorry about all the questions
Re: (heha)
Posted: Mon Sep 12, 2005 11:57 am
by BlueCrush
No Problem. If you get a factory S/C it does come with everything you will need if you keep everything stock on your engine. Including the S/C ECU. If you add an intake or exhaust it will change the a/f ratio and you will need to then use an aftermarket piggyback ecu, a fifth injector controller or a W/I system so you don't run lean and destroy your engine.
Posted: Mon Sep 12, 2005 12:15 pm
by heha
ok question about clutches.. If I bought a new clutch and its a six speed and my car was a five speed will this screw things up?
Re: (heha)
Posted: Mon Sep 12, 2005 12:18 pm
by BlueCrush
You might want to start a new thread for that question so the right people see it.
Posted: Mon Sep 12, 2005 12:25 pm
by heha
sorry, thanx I did.thanx again for all the help blue crush you've been a big help.
