Anyone with a SC have the template for cutting the engine cover?
Posted: Sun Sep 11, 2005 3:09 pm
by damronjr
My SC didn't come with one and I prefer the look of the template-cut cover rather than the straight across cut cover. If you know where I might find one that would be just as helpful. Thanks!
Re: Anyone with a SC have the template for cutting the engine cover? (damronjr)
Posted: Sun Sep 11, 2005 3:31 pm
by Faultline
I haven not had mine on for quite awhile,and as far as I know, it is at the SF shop. So, no. I do not have a template, but if you screw up cutting yours , let me know, I will give you mine (As long as I can find it)....I aint never going to need mine again..
Re: Anyone with a SC have the template for cutting the engine cover? (Faultline)
Posted: Mon Sep 12, 2005 8:05 am
by damronjr
Thanks, Faultline. Hopefully I can find someone who still has theirs, like maybe SoCalVibe, or SCVibe, or maybe even Lancer or Bluecrush. Didn't Sunny get one as well?
Posted: Mon Sep 12, 2005 8:57 am
by BlueCrush
I have a template for the engine cover that I haven't used yet. If you can't find anyone locally I can mail it to you so you can use it to trace. I will need it back though.
Re: Anyone with a SC have the template for cutting the engine cover? (BlueCrush)
Posted: Mon Sep 12, 2005 8:58 am
by damronjr
Quote, originally posted by BlueCrush »I have a template for the engine cover that I haven't used yet. If you can't find anyone locally I can mail it to you so you can use it to trace. I will need it back though. Thanks Brian! Still trying here and on MO, but no luck yet. I'll let you know if I can't get ahold of one in a few days and see if I could borrow yours. Really appreciate it!
Posted: Mon Sep 12, 2005 9:16 am
by BlueCrush
No Problem.
Posted: Thu Sep 15, 2005 12:32 pm
by Lancer
Mine's a little chewed up from the tape I used. Turned out ok but needs some work and a repaint and decaled. A little advice, Unless you have used a dremmel a lot, don't use one now for your first time. I used my Bro'-in-law's and he said to use the bit cutter thingy. That just chewed the plastic up. I ended up using the cutting wheel and a jig saw blade then smoothed things out with the sanding wheel on the dremel tool and finally some sandpaper. I still have a weekend of work to do on it.
Re: Anyone with a SC have the template for cutting the engine cover? (Lancer)
Posted: Thu Sep 15, 2005 12:56 pm
by BlueCrush
I made a copy of my S/C template and sent it to him this morning along with a couple things he bought from me. Good tips on how to go about cutting in though. It may come in handy. Thanks.
Posted: Thu Sep 15, 2005 1:43 pm
by damronjr
Thanks Lancer and Brain! I thought about the dremmel thing, but like you said, I've never used one before so maybe I better look into other options! Thanks for the tips and sale!
