Has anyone tried the Air Intake mod?
Posted: Thu Sep 08, 2005 1:34 am
by gdizzle
I've seen on eBay and TV this little round metal disc, that has slots in it. To make the air into a Vortex as is goes into the engine. Its pretty cheap. Supposed to give better MPG and hp. Is this for real, or is it a scam? TV has it for $75, but on eBay its much less.Anyone?diz
Posted: Thu Sep 08, 2005 1:37 am
by northvibe
Re: (northvibe)
Posted: Fri Sep 09, 2005 10:39 am
by mcgusto82
after reading a few pages worth of replys, there was nothing really intelligent said. jet engines... aircraft jet engines (ducted, supersonic)have what is called a vortex generator. the tornado is that. it creates a flow for air to fallow. the preassure loss in the cylinder sucks air in. the vortex generator removes turbulance that keeps air from from flowing as fast as it can. in my opinion.. it might work. keeps everything looking stock if that's what you want.CAI are not always the best way. specially when paying 200$ some dollars (AEM). why don't you get, if it works let us know. if it doesn't. put it back on ebay.
Re: (mcgusto82)
Posted: Sat Sep 10, 2005 3:07 am
The engine in a vibe works a little differently than a jet engine. I think that if a little shaped piece of metal could boost HP and MPG, then the car makers would put one in. I expect they spend a lot of money in research to improve power and efficiency. Anyway, would be great if it worked, but I am not going to risk any money on it because I have serious doubts.
Posted: Sun Sep 11, 2005 4:55 am
by tangerine
those vortex intakes work.
Re: (tangerine)
Posted: Sun Sep 11, 2005 1:47 pm
by Thewhite
all cars journalists will give you the same answer: none of these fuel saver gadgets work...
Posted: Sun Sep 11, 2005 10:39 pm
by tangerine
Don't beleive reviews till you try it. I put the vortex in our SS and it brought it from 12.9mpg-17mpg
Re: (tangerine)
Posted: Sun Sep 11, 2005 11:56 pm
by Flip-Side
I tried it in my old S-10 and it made my mpg worse. The air going into your engine is not a constant flow. I don't believe those venturi things work at all.
Posted: Mon Sep 12, 2005 12:07 am
by tangerine
maybe you had it in backwards or its not the same product.
Posted: Mon Sep 12, 2005 12:21 am
by JustinVGT
I would think manufacturers would implement something like this stock if it increased gas mileage, especially in a truck from 13mpg to 17 mpg. I mean, that's an increase of over 30%. I would just think if it worked that great all the time, these things would be more widely used and known to work.
Posted: Mon Sep 12, 2005 12:34 am
by tangerine
You'd think they would. They may not all work since they are not all the same but the one we purchased at pepboys works great. I told my dad they were a joke but he said they have been around for years so he put one in our truck and it actually does work.
Posted: Mon Sep 12, 2005 4:55 am
by nortsr
How much was the one that you bought at PepBoys?? and What was it called????
Re: Has anyone tried the Air Intake mod? (gdizzle)
Posted: Mon Sep 12, 2005 7:42 am
by tangerine
$35 I think? Its called Vortex.
Re: (tangerine)
Posted: Tue Sep 20, 2005 4:42 am
by cknight725
Quote, originally posted by tangerine »those vortex intakes work.Yeah and those Holley, Edelbrock, and Injen stickers add 25HP ...A Vortex is turbulence, turbulence in the top end of an engine is bad. You end up with very well atomized fuel in a very turbulent flow of air into your engine ... end result, little or no gain whatsoever.Do yourself a favor -- pass on this and buy and equally useless strut tower brace -- at least you can see it ....
Re: (Flip-Side)
Posted: Tue Sep 20, 2005 4:55 am
by cknight725
Quote, originally posted by Flip-Side »I tried it in my old S-10 and it made my mpg worse. The air going into your engine is not a constant flow. I don't believe those venturi things work at all.Actually, if this item had anything to do with the Venturi effect it would help quite a bit, but only above say ... 5000RPM and it might make 4-5 HP more in that range. A Venturi is basically a cone that is designed to create a denser charge of air because the entrance of the cone is wider than the exit -- a byproduct is a slight spin to the air, but the benefit is not in the spin, its in the denser charge of air. It only works at high RPM though. You'll find drag cars and race cars that run at high RPM with large venturi stacks, but their engines spend their entire lives above 6000 RPM ...Tornado is a vortex without the venturi effect whatsoever -- basically just a turbulence adder.Why is turbulence bad -- well, why is porting and polishing your heads good? The rough areas inside the runners of your heads make the charge of air more turbulent. To remove that turbulence you use a mill to polish the surface of the runners to eliminate turbulence. Only a tard would add something to make the air more turbulent ...
Re: (cknight725)
Posted: Tue Sep 20, 2005 5:32 am
by Flip-Side
Oops, I meant vortex not venturi. I didn't even know they used venturis in race cars, so I learned something new from my brain fart. My whole point about the vortex is that it is supose to flow air more effectively by forcing it to spin like a wirlpool. Won't work in an engine since the flow is not constant, and more or less pulses.
