HeadLight aim..........
Posted: Mon Dec 16, 2002 11:06 am
by Pump233ca
Took some tinkering...but finally got the Headlights pointing in a comfortable position....I can`t believe this hasn`t come to the point of Service Bullatin...I realized that the light pattern is very similar to that of some H4 Quartz Lights I had some years back....anyways the they shine further down the road.
Re: HeadLight aim.......... (Pump233ca)
Posted: Fri Dec 20, 2002 6:37 am
Where is the adjustment for them? I looked EVERYWHERE behind the lights, and couldn't find anything. The ONLY thing I could find was a screw that had teeth coming down from it, but it was SO far down, I couldn't reach it, and figured that wasn't it....advice please!
Re: HeadLight aim.......... (ragingfish)
Posted: Fri Dec 20, 2002 6:46 am
by NSimkins
quote:Where is the adjustment for them? IThere is an adjustment screw behind each headlamp. See this thread for more info:
http://forums.genvibe.com/zerothread?id ... =6195#6195
Re: HeadLight aim.......... (NSimkins)
Posted: Fri Dec 20, 2002 6:54 am
I'm gonna run on the assumption it is the screw I saw...if that's the case, how can you get to it on the passenger side if you have ABS? I have the ABS boxey thing there with tons of tubies coming out of it, I can't get to that screw without hitting them. Thoughts?
Posted: Fri Dec 20, 2002 7:02 am
by NSimkins
It's also a bolt (and you can use a stubby screwdriver).. you can use a socket w/ rachet to get into the tight space. That's what I did, but I don't have ABS.
Posted: Mon Jan 06, 2003 7:23 am
by mu_ohio
I would suggest not installing a CAI before aiming your lights. I just tried to do mine and the passenger side is blocked by the tube. Guess I'll try using a screw driver later.
Re: HeadLight aim.......... (mu_ohio)
Posted: Mon Jan 06, 2003 12:37 pm
what's a CAI?
Posted: Mon Jan 06, 2003 2:42 pm
by CrazyJ-GT
CAI = Cold Air Intake
Re: HeadLight aim.......... (CrazyJ-GT)
Posted: Mon Jan 06, 2003 2:43 pm
Did I miss something? Did anyone mention a cold air intake? LOL! I think you have the wrong thread, but I could be wrong.
Posted: Mon Jan 06, 2003 9:04 pm
by NSimkins
quote:Did I miss something? Did anyone mention a cold air intake? LOL! I think you have the wrong thread, but I could be wrong. No, mu_ohio stated that the presence of a CAI will affect the aim adjustment of the driver's side headlight. Then you asked what CAI stood for and CrazyJ-GT responded with an answer. Everything looks ok to me.
Posted: Mon Jan 06, 2003 11:48 pm
i get it now...he was just throwing that out there as a general thought...don't mind me all, i'm just a little slow on the uptake.
