High Idle at start-up with Vibe after Injen CAI install
Posted: Wed Sep 07, 2005 7:40 am
by kimchimik
Hi all I installed a Injen CAI and i'm getting a 2k idle on start up and drops as the engine warms up. I live in california so it's not too cold in the morning. I know i have to let the ECU learn i so i'm just wondering how long it takes to have it return to normal idle it has been 3 days now, is this something to worry about or am i just being too impatient?
Re: High Idle at start-up with Vibe after Injen CAI install (kimchimik)
Posted: Wed Sep 07, 2005 7:48 am
by damronjr
Did you remove the negative lead from the battery and let it sit about 15min? I didn't but still didn't notice this, but from what I've heard you are supposed to.
Posted: Wed Sep 07, 2005 7:54 am
by kimchimik
yeah did that and let it idle for 10 minutes drove it to work and back yesterday and a little bit on labor day.
Re: (kimchimik)
Posted: Wed Sep 07, 2005 8:22 am
by damronjr
It still idles at 2k rpm on start-up? That surely isn't right. Did you move or adjust the throttle cable any?
Re: (damronjr)
Posted: Wed Sep 07, 2005 8:24 am
by Mavrik
Not sure about you guys but my Vibe has always idled high, around 1500-1800RPM on initial start up until ithe engine warmed up and then it would drop under 1000RPM. Sounds louder with the intake...
Re: (Mavrik)
Posted: Wed Sep 07, 2005 8:31 am
by damronjr
Quote, originally posted by Mavrik »Not sure about you guys but my Vibe has always idled high, around 1500-1800RPM on initial start up until ithe engine warmed up and then it would drop under 1000RPM. Sounds louder with the intake...Never thought about a start from cold, I usually notice when I start shortly after a previous run!
Re: (kimchimik)
Posted: Wed Sep 07, 2005 9:03 am
by Lancer
It's normal. You have to be driving the car for about a week for the ECU to learn. Not just driving it a couple times in a few days. The more you drive it the faster it will learn.
Posted: Wed Sep 07, 2005 11:14 am
by kimchimik
No i did not adjust the throtle or anything. The only thing i did was clean the MAF sensor with some carbarator cleaner but i left that out to try for an hour before i put it back in.But if you guys are saying a week i guess i should plan a long road trip this weekend and get it out of the way.
Posted: Wed Sep 07, 2005 11:34 am
by AKLGT
yes, mine always started up high and then slowly went back down to almost nothing.
Posted: Wed Sep 07, 2005 2:25 pm
by northvibe
ah good to know! thnx for the tip.
