Glass Hatch
Posted: Tue Jun 18, 2002 12:05 pm
by Doubull
Does anyone know if the glass hatch can be "popped" with the remote keyless entry?
Re: Glass Hatch (Doubull)
Posted: Tue Jun 18, 2002 8:12 pm
by millster
It sure can. There's a button right on the remote labeled hatch.
Re: Glass Hatch (millster)
Posted: Tue Jun 18, 2002 11:23 pm
by Doubull
The button on the remote will actually open the glass hatch? Is there a special way to push the button, or do you just hit it once? Mine will not open unless I push the button on the inside of the car for the glass hatch.
Posted: Tue Jun 18, 2002 11:27 pm
by ChuckP
You have to hold it down for about 3 to 4 seconds,then it will open.
Re: Glass Hatch (ChuckP)
Posted: Wed Jun 19, 2002 3:43 am
by Doubull
I wish they would have told me that when I got it. It works when I hold down the button. Thanks.
Posted: Fri Jul 19, 2002 9:36 am
by mwstate
The dealer.salesman did not know this either. I just wish the back hatch would lock with the doors. I am always leaving it unlocked!
Re: Glass Hatch (mwstate)
Posted: Fri Jul 19, 2002 1:32 pm
by NSimkins
quote:I just wish the back hatch would lock with the doors. I am always leaving it unlocked!What do you mean? I thought the hatch did lock with all the doors? More info please?
Re: Glass Hatch (NSimkins)
Posted: Sat Jul 20, 2002 8:28 am
by Lori19
I would like more info too! I just press the button while walking away and never check!Now there's blind faith for ya!
Re: Glass Hatch (Lori19)
Posted: Sat Jul 20, 2002 8:32 am
by VibeInTx
The glass hatch "locks" when it is closed correcty. I think the original poster is refering to the fact that if you do a hatch release, and then a door lock, the hatch is still unlocked. The only way to lock the glass hatch is to open and close it after it's unlocked.
Re: Glass Hatch (VibeInTx)
Posted: Sat Jul 20, 2002 1:24 pm
by NSimkins
Ahh, I understand now.... and that is correct, as I have just tried the steps you have mentioned. Thanks.
Posted: Thu Sep 05, 2002 7:20 am
by PJE
With my Vibe the only way to lock/unlock the rear door (not glass) is via the key!!!!!! (Base with Power Package)I have just been going about my business for the two weeks I've had my car with the tailgate unlocked...Why doesn't it lock/unlock with the other doors?The way it is is VERY frustrating...My 2cPJEPS. Does anyone know anyone offering a service to add a solenoid to the rear lock and tie it into the other doors. TIA
Re: Glass Hatch (PJE)
Posted: Thu Sep 05, 2002 7:23 am
by millster
If you have the power package, it should unlock with the other doors (using lock and unlock from the keyfob). You should probably have that looked at by your dealer.
Posted: Thu Sep 05, 2002 10:22 am
by NovaResource
The rear hatch (not glass) unlocks with the key fob however, you have tto push the button twice. If you push the button once, it only unlocks the driver door. Push the button twice and it unlocks all the doors including the hatch.The glass unlocks with the hatch button on the fob but you have to hold the button down for about 2 or 3 seconds.
Posted: Mon Sep 09, 2002 10:57 am
by mu_ohio
quote:With my Vibe the only way to lock/unlock the rear door (not glass) is via the key!!!!!! (Base with Power Package)I have just been going about my business for the two weeks I've had my car with the tailgate unlocked...Why doesn't it lock/unlock with the other doors?The way it is is VERY frustrating...My 2cPJEPS. Does anyone know anyone offering a service to add a solenoid to the rear lock and tie it into the other doors. TIALike one of the other posters stated, the hatch should lock/unlock with the fob. If you push the unlook twice, you will hear a lowd unlock from the hatch itself. That's about the only way I know I got all the doors to unlock.
Posted: Tue Dec 28, 2004 9:31 am
by zionzr2
CAN I add a (glass hatch) release button to a non power package vibe?? Easily like is the wiring there it just needs the switch, or would it be way more complicated?
Posted: Tue Dec 28, 2004 11:04 am
by Jahntassa
You'd have to put an actuator on the glass release, just like on the hatch, so it'd probably be more complicated..
Re: (Jahntassa)
Posted: Tue Dec 28, 2004 10:27 pm
by esjones
Quote, originally posted by Jahntassa »You'd have to put an actuator on the glass release, just like on the hatch, so it'd probably be more complicated..Since there is a glass release button on the instrument panel, doesn't that mean that the actuator and wiring is already there?
