Dash Button
Posted: Mon Dec 16, 2002 2:49 am
by daverules
I figured out what to do with the blank, unuseable button next to my radio
Re: Dash Button (daverules)
Posted: Mon Dec 16, 2002 3:29 am
by slbpsi63
Dude.......Where is the escape hatch? you might end up like Goose in Top Gun.
Posted: Mon Dec 16, 2002 4:22 am
by Sub-Vibe-R
It will be hard to install something at this place. The reclycle wire is hooked here. There's a big connector at that place. If you want to add some button, it will be easier to put them beside the hatch button, on diver side.
Re: Dash Button (Sub-Vibe-R)
Posted: Mon Dec 16, 2002 4:27 am
by Stang2Vibe
What the heck is the blank useless button there for anyway? Is it functional with the nav system or something? I've been wondering about it since I got my Vibe. I have the moonroof, so the eject button might work for me if I lean back and to the right a little bit. Wouldn't recommend pressing it inside the garage, though (see pic above)!
Re: Dash Button (Stang2Vibe)
Posted: Mon Dec 16, 2002 4:33 am
by Sub-Vibe-R
may be it will be used in the next James Bond movie, when he will be using a Vibe.
Posted: Mon Dec 16, 2002 8:48 am
by Pump233ca
I installed a little light to remind me "my wife" that the Driving Lights are on..
Posted: Mon Dec 16, 2002 11:48 am
by KSNeptune
I personally think it would be a great place to mount an 1/8" mini stereo jack for plugging in auxiliary music device(s). Perhaps pressing it in would then open it up to reveal the jack and maybe a volume (input level) knob.Now if only the 'Tunes single CD radio had AUX inputs on the rear. I guess that's why we have an aftermarket.... cause the original manufacturers never quite get it right. That overpriced option should of AT LEAST been able to play MP3's off a CD rom!KSNeptune
Re: Dash Button (Pump233ca)
Posted: Tue Dec 17, 2002 4:47 am
by slbpsi63
quote:I installed a little light to remind me "my wife" that the Driving Lights are on.. I feel your Pain... they never think we can remember to put them on.
Posted: Tue Dec 17, 2002 5:33 am
by KSNeptune
Maybe they simply put it there to confuse buyers. Or perhaps it was simply to balance the look of the dash layout. I'm "almost" certain there must be some option now or next year that will utilize that button. Heated seats, perhaps?KSNeptune
Posted: Tue Dec 17, 2002 2:28 pm
by vibegirl
Looks great!
Re: Dash Button (vibegirl)
Posted: Wed Dec 18, 2002 6:34 am
by TGebiV
it is where you put your NOS button when your warrenty runs out!!!!!
Re: Dash Button (s5amiller)
Posted: Wed Dec 18, 2002 7:14 am
by Shadow Realm
Maybe you can use it to turn on the afterburner when it gets installedThe 9000HP Vibe. Of course you could only go in a straight line, but if you added wings you could be the first Vibe to cross the Atlantic
Re: Dash Button (Shadow Realm)
Posted: Wed Dec 18, 2002 10:20 am
by daverules
quote: afterburner hmmm afterburner, good idea
Re: Dash Button (KSNeptune)
Posted: Thu Dec 19, 2002 2:02 pm
by Jethro
quote:Maybe they simply put it there to confuse buyers. Or perhaps it was simply to balance the look of the dash layout. I'm "almost" certain there must be some option now or next year that will utilize that button. Heated seats, perhaps?KSNeptuneMy guess would be for balance in the layout. I think it would have been a much better location for the Parking Brake indicator - it blends in too easy where placed in the red gauge cluster.If you look at the pictures of the VOLTZ dash the buttons for the A/C and Recirc are moved down, then the rear window defrost takes over the top spot while the separate clock (which I prefer over the one built-in to the M&T single-CD/radio) gets a home in the place of the r/w defrost on the VIBE.The VOLTZ - minus the annoying Daylight Sentinal (Daylight Senile is more like it) - also has a separate, lighted switch for the driving lamps in the lower dash by the coin holder and rear hatch release. I'd rather have that over the hard to use stalk mounted switch too.NUMMI, are you listening?
Posted: Fri Dec 20, 2002 10:44 am
by Sam2Mar
Do you have the location and the wiring color to install a indicator light for the driving lights.Thanks!"LD Blue" Vibequote:I installed a little light to remind me "my wife" that the Driving Lights are on..
