GM Standard GM6094M for motor oil
Posted: Wed Aug 31, 2005 4:33 am
by Tazz602
The 05 Vibe owners manual specifically states that I should only use oil that meets GM6094M standard and has the API starburst symbol on the container.Bottom line question for me on this is - how important is it to get this "GM" certified oil when this is a Toyota engine?? What does the Matrix manual say to use for oil? I ask because the only 5w-30 weight oil my local Grease-N-Go has is Valvoline - and they have been doing minor maintenance like this on my cars for years and I trust their work - so it seems stupid that I'm looking for a GM specification for a Toyota engine and not able to use people I trust to work on my car.Thoughts? If I'm changing my oil on schedule and not driving in races should it be an issue?
Re: GM Standard GM6094M for motor oil (desert_dweller)
Posted: Wed Aug 31, 2005 5:13 am
by drunkenmaxx
reading way to into it man. if it's for gasoline engines and is 5w-30, everything be ok!however, make sure to check your blinker fluid.
Re: GM Standard GM6094M for motor oil (drunkenvibe)
Posted: Wed Aug 31, 2005 6:12 am
by BOZACK
Quote, originally posted by drunkenvibe »reading way to into it man. if it's for gasoline engines and is 5w-30, everything be ok!however, make sure to check your blinker fluid.Thanks, Drunken. I just ran out and checked my blinker fluid. Damn, if it was not almost empty. That was a close one.
Re: GM Standard GM6094M for motor oil (BOZACK)
Posted: Wed Aug 31, 2005 6:34 am
by Tazz602
What about the AAA batteries for the dashboard lights?
Re: GM Standard GM6094M for motor oil (Tazz602)
Posted: Wed Aug 31, 2005 9:39 am
by Tazz602
Thanks all - common sense got back control - I just wanted to do right by my new obsession - first oil change and all -
