a better sub that fits in the moon and tunes 10" spot?
Posted: Sat Aug 27, 2005 7:53 am
by Mook
I have a 2005 vibe with the moon and tunes system, and i keep blowing the sub. i never really go ver 4 bars and i usually turn the bass to 0 or even -1 sometimes. Is there a more powerful sub that will fit in the old subs compartment?
Re: a better sub that fits in the moon and tunes 10" spot? (Mook)
Posted: Sat Aug 27, 2005 7:55 am
by Kari
If you haven't done anything unusual volume-wise, the problem may not be with the sub itself, but perhaps the amp is defective and pushing out something that the sub can't handle. ColonelPanic had 3 speakers blow at once while listening to NPR of all things, and it seemed to be the amp that was the culprit.
Posted: Sat Aug 27, 2005 7:57 am
by BlueCrush
Huh! I've been at 6 bars with the base at +3 numerous times and have had no problems. Have you have the dealer look at it to make sure everything is ok with the wiring and the amp?Welcome to GenVibe!!!
Posted: Sun Aug 28, 2005 12:25 am
by Toasted7
I think you might have another issue... I have mine up a lot louder than that and I have no problems with it.
Re: a better sub that fits in the moon and tunes 10" spot? (Toasted7)
Posted: Sun Aug 28, 2005 11:41 pm
by Mook
well do you guys listen to real bass heavy music, like rap? Cause with some of the rap cds that i have have such heavy bass i dont even turn the volume past 3 bars
Posted: Mon Aug 29, 2005 1:21 am
by Jahntassa
If you've blown the sub multiple times, i'd say there's something wrong either with the radio or amplifier.Finding an aftermarket sub to replace that one could be potentially expensive, and a pain to get working correctly..
Posted: Mon Aug 29, 2005 1:59 am
by cieglo
I've got a 2003, and crank it all the time w/o problem. here's my question: where the heck is the subwoof?
Re: a better sub that fits in the moon and tunes 10" spot? (cieglo)
Posted: Mon Aug 29, 2005 2:57 am
by FrostyVibe21
Quote, originally posted by cieglo »I've got a 2003, and crank it all the time w/o problem. here's my question: where the heck is the subwoof?You don't have one in a 2003, they are only in the 2005 and later.To answer your question though, they are mounted in the cargo area near the wheel well.
Posted: Mon Aug 29, 2005 12:03 pm
by binary
Quote, originally posted by Mook »well do you guys listen to real bass heavy music, like rap? Cause with some of the rap cds that i have have such heavy bass i dont even turn the volume past 3 barsYeah, I listen to Rap, Blues, Metal, Rock, and just about everything else - cranked sometimes to 80-90%... never blown a speaker. Get your amp replaced...Back to the original question - I don't know what would fit in the oem sub area, it's a oddball shaped box. The sub would have to be 2 ohm if you'd like the Monsoon amp to power it efficiently.
Posted: Wed Aug 31, 2005 1:05 am
by Mook
alright well I think i"ll take it in to the dealer and have them check out the amp. thanks alot for the info
Re: (Mook)
Posted: Fri Sep 02, 2005 11:57 am
by dan326
Just a thought. What is the size of the sub in the 05 m&t. I thought it was like 5 or 6 inches. What would happen if you put an after market speaker that wasn't necessarily designed as a sub? Maybe a door speaker, but one that isn't a two or three way.You mention it needs to run at 2 ohms to work properly, but I don't really know if this type of speaker exists.Thoughts?
Posted: Sun Sep 04, 2005 1:17 am
by tangerine
the sub is an 8 inch. when I was thinking of buying a vibe again I had someone crack the back panel open and let me have a look in our shop and you can replace the sub but I wouldn't advise it. If your wanting good bass I'd just disconnect that sub and use the amp to power your speakers and put a real system in the cargo area. As for blowing that many times there is obviously a problem in the grounding, hell MTX doesn't even go out that fast.
Posted: Mon Sep 05, 2005 8:45 am
by restanim
The M&T Sub ia a 6.5" dual voice coil woofer. Each vioce coil is rated at 2 ohms. I Replaced the M&T amp with two Sony XM-2100GTX amps (89.99 each at Circuit City). One amp for the sub and the other for the front speakers. The head unit and door speakers were replaced. The system sounds much more clearer and is more powerful.
