Hidden Hitch from Etrailer
Posted: Sat Aug 27, 2005 6:25 am
by Vibetastic
Has anyone bought this hitch from Etrailer?Does it include the ball mount and installation hardware. I assume it does not include the ball.Charles
Re: Hidden Hitch from Etrailer (Vibetastic)
Posted: Sat Aug 27, 2005 6:36 am
by 2001FZ1
I have bought a few hitches in the past from other places. Unless you order it, most likely the ball mount will not come with the hitch. ball mounts are universal and can be bought from almost any auto part store or even wal-mart
Posted: Sat Aug 27, 2005 7:09 am
by NSimkins
Quote, originally posted by Vibetastic »Has anyone bought this hitch from Etrailer?Yep, I bought this hitch from ETrailer.com a couple years ago.Quote »Does it include the ball mount and installation hardware. I assume it does not include the ball.When I bought mine, it included the hitch, 4 bolts to mount to the Vibe's body, and a rubber cap for the hitch opening. No ball. Installation is a breeze, just screw in the 4 bolts, torque down (if possible) and you're done.Had a good experience with ETrailer.com too, so you should be set. I'm not sure, but if there is a coupon, promotion, or discount box when you check-out, enter "genvibe" and see if their discount for us is still valid. Hidden Hitch pics:
http://forums.genvibe.com/zerothread?id=5862
Posted: Sun Aug 28, 2005 12:06 am
by vibe-anator
No holes to drill? Is ther already holes in the frame that match the hitch?How much was shipping and how long did it take to get to you?
Re: (vibe-anator)
Posted: Sun Aug 28, 2005 12:24 am
by vibe-anator
answered my own question. I just ordered on for myself aloong with the 4" raised ball mount.Now for the wiring: Which wiring kit do you guys use? how easy is the install of the wiring?Thanks
Re: (vibe-anator)
Posted: Sun Aug 28, 2005 12:39 am
by rasermon
Trailer Wiring Info. Do it yourself with pics. (cohocarl)
http://forums.genvibe.com/zerothread?id=1139If you have any question, send cohocarl a IM.
Re: (rasermon)
Posted: Sun Aug 28, 2005 2:22 am
by Pick
I had good luck with etrailer also, got the wiring from them also. Very simple install thanks to the above mentioned wiring thread. It's funny though, they send this little bitty hitch in a HUGE box lol
Posted: Sun Aug 28, 2005 6:34 am
by the_nite_owl
I bought the hidden hitch last month.I did a writeup in one of the threads about my install. Very easy to install, no drilling required. Bolts in to existing frame holes specifically for this purpose.WIRING: I bought the 18130 taillight converter box for hardwiring into the taillights.Now that I have them wired in I find that they do not work well.There is not enough current coming off the wiring for the tail lights. If you are driving with your headlights on and use your turn signal the voltage drops so much that both sides seem to be flashing together rather than one signal flashing.Driving without lights on the signals and brake lights work fine.I would suggest buying the more expensive taillight converter that uses it's own power source (12v wire you run to the box) to power the lights so it does not rely on the power at the existing lights.The one problem I have is that in my AWD Vibe the hitch is so close to the muffler that when turning corners it starts tapping against the hitch frame. Not bad and only on corners that are a little bumpy.
Just an update
Posted: Fri Dec 30, 2005 11:53 pm
by Mathias
This morning, I ordered a Hidden Hitch from etrailer, and put "genvibe" into what they call the "Reference box" or some such.Sure enough, $6.99 discount.-MathiasEast Lansing, MI
Posted: Sat Dec 31, 2005 3:09 am
by Baltovibe
I think I like the Draw-Tite hitch better from etrailer ... it is about $20 cheaper, and is held on by six (6) bolts, not only four (4) bolts on the Hidden Hitch.Oops ... the Hidden Hitch apparently "Includes drawbar, pin and clip", whereas the Draw-Tite does not. Also, GenVibe member "the_nite_owl" states that his Hidden-Hitch rattles against his exhaust at this thread.
