5spd and playing with the radio
Posted: Fri Aug 26, 2005 12:52 am
by hjwii
Okay.. I have a 5spd... and I have a radio... and when I'm in 3rd or 5th gear, it's the perfect resting spot for my hand while I play with the radio. Is this putting undue strain on the stick and the clutch and all? I try to refrain from resting it there, but sometimes I just forget... Thanks,,,hjwii :^)
Posted: Fri Aug 26, 2005 1:14 am
by Pick
If it breaks from your hand resting on it then it's a POS and deserves to be broke.
Re: 5spd and playing with the radio (hjwii)
Posted: Fri Aug 26, 2005 1:32 am
by ToolGuy
Yeah it should be fine! You are actually resting on the shifter itself and not the clutch. I do the same on my 6-speed with no issues.
Posted: Fri Aug 26, 2005 1:45 am
by JustinVGT
Yeah, I do the same thing with my 6 speed. What you don't want to do is rest your foot on the clutch pedal.
Re: 5spd and playing with the radio (JustinVGT)
Posted: Fri Aug 26, 2005 2:03 am
by Mavrik
I've been resting my hand on the shifter ever since I learned how to drive.
Posted: Fri Aug 26, 2005 2:51 pm
by Jahntassa
Agreed. It's fine. The shifter actually connects to the gearbox via cable, so all you're doing is putting weight on the structure holding the shifter in place.. Which..yes..will support it.
