Headlamp Removal
Posted: Thu Aug 25, 2005 1:30 pm
by Abyss AWD
Is there any instructions on how to take out the headlamp assembly?I installed those "eurolite" made by Toucan Industries, and it blew up, and I need to remove the residue it left behind.I did a search and nothing came up.
Re: Headlamp Removal (Abyss AWD)
Posted: Thu Aug 25, 2005 1:43 pm
by Storm
do you mean the housing? Like the whole headlight? if it's anything like the matrix, which I'm sure it is, there are 3 screws. you can get off the third you need to take off the bumper for. First screw, or bolt 10mm I believe, is up by the turn signal, second is down to the right, or left, of the high beam depending which one you're at. third is under the bumper on the side above the wheel well. If you take it out and clean it be careful when you put it back on cause you will need to adjust the aim of the lights.
Posted: Thu Aug 25, 2005 2:39 pm
by Abyss AWD
thanks very much!I knew there was a 3rd one some where, I will have to check out tomorrow
Posted: Thu Aug 25, 2005 2:53 pm
by Storm
if you need help taking the bumper off it's simple. 4 bolts underneith, 2 bolts in the wheel well, 2 screws under the hood, and 3 pins, one is obvious under tthe hood. right in the middle, but the other 2 are under the actual bumper its the same type pin as the one under the hood just feel around for them
Posted: Thu Aug 25, 2005 3:05 pm
by Abyss AWD
The bumper HAS to come off?
Re: (Abyss AWD)
Posted: Thu Aug 25, 2005 5:31 pm
by ragingfish
Quote, originally posted by Abyss AWD »The bumper HAS to come off?Yes.http://forums.genvibe.com/zerothread?id=12551
Posted: Thu Aug 25, 2005 11:58 pm
by Abyss AWD
Thank you very much! thats awesome!
Posted: Sat Nov 28, 2015 9:43 am
by treesleavedents
Dead thread revival, can we please fix this link somehow? Or get a new link as I haven't been able to find the front bumper removal thread using the search engine...
Posted: Sat Nov 28, 2015 1:08 pm
treesleavedents wrote:Dead thread revival, can we please fix this link somehow? Or get a new link as I haven't been able to find the front bumper removal thread using the search engine...
The forum software updated a few years back,, renumbering threads, but not all the links got updated
viewtopic.php?t=9959
Another good thread by ragingfish made less useful by him posting his pictures on an external site, then moving on and deleting his image hosting
Posted: Sat Nov 28, 2015 1:55 pm
by treesleavedents
thanks!!
