17"
Posted: Thu Aug 25, 2005 12:25 am
by Abyss AWD
I have a 2005 AWD Vibe, with the stock steel wheels, hubcaps. What is the OEM tire size of the 17" wheel package?
Posted: Thu Aug 25, 2005 1:42 am
by ragingfish
215/50/17I don't believe the AWD is rated for 17's though.
Re: (ragingfish)
Posted: Thu Aug 25, 2005 2:08 am
by BlueCrush
As long as you keep the same overall diameter you will be fine with 16's, 17's or 18's. I have 18's on my AWD and I love them. The stock 16's will go back on for winter though.
Re: (BlueCrush)
Posted: Thu Aug 25, 2005 2:41 am
by Mavrik
If your on stock P205/55R16 rims and want to switch to a 17" rim, do not go with the stock 17" Vibe tire size as its to big. To best keep tire size diametre correct, you'll want to run P225/45R17 to match nearly perfect with the P205/55R16.If you put on to big or to small a tire, you risk throwing off your odometre, speedometre, fuel consumption, abs brake systems, and over all vehicle handling.
Posted: Thu Aug 25, 2005 3:59 am
by Abyss AWD
Thanks for the input guys!Much appreciated.This maybe off topic....but does anyone know the offset of the Vibe AWD?
Re: (Abyss AWD)
Posted: Thu Aug 25, 2005 5:37 am
by Mavrik
5-100... the awd should be the same as the base. offset... man I'm scratching my head on this one. I did all the research myself for my Vibe, got the work done and forgot it... 38-42 offset allowed? damn wish I could remember, this is bad.
Re: (ragingfish)
Posted: Thu Aug 25, 2005 5:49 am
by drunkenmaxx
Quote, originally posted by ragingfish »I don't believe the AWD is rated for 17's though.what's your basis for this statement?you seem to dislike the AWD crowd or something. you once told someone not to get a CAI because the tranny on the AWD couldnt handle it.the only car that they wouldn't offer with 17s (this may have changed now) was those w/moons and tunes, because of the moonroof.
Re: (drunkenvibe)
Posted: Thu Aug 25, 2005 10:38 am
by 4X4CHICHI
mine came with moons and tunes and 17's
Re: (4X4CHICHI)
Posted: Thu Aug 25, 2005 10:10 pm
by drunkenmaxx
Quote, originally posted by 4X4CHICHI »mine came with moons and tunes and 17'swell, there ya go, it has changed.
