Rail Removal for Painting
Posted: Fri Aug 19, 2005 1:28 pm
by harryyiii
I am thinking about having the roof rack bars powder coated black. Silver bars were a poor design choice by Pontiac. How do you get them off? There are good posts on how to get the rear cover off for removing the cross bars. However, what would be the next step? I don't want to take the headliner or trim inside off if possible, in other words minimize dis-assembly. As a side question, has anyone removed the grill on a 2005. I am thinking about painting that black also.
Re: Rail Removal for Painting (harryyiii)
Posted: Fri Aug 19, 2005 2:04 pm
by BOZACK
http://forums.genvibe.com/zerothread?id=18289Try this thread. Disneydj has pis of his off. He states each is held on with four screws. Althought it does not explain how to do it.
Posted: Fri Aug 19, 2005 3:01 pm
by zionzr2
talk to Sherry2he had his bars powdercoated!!
Posted: Fri Aug 19, 2005 3:31 pm
by ragingfish
Remove crossbars if necessary.Remove endcaps from both ends of each rail (4 total).Remove 4 bolts (per rail), at each end, that secure rails to roof (will be under caps you just removed).Disengage 3 plastic retainers found towards the middle of the rail.Repeat for other rail.
Re: (ragingfish)
Posted: Fri Aug 19, 2005 10:02 pm
by scherry2
thanks Mike,what he said about covers it they come off pretty easy. I had a R and R but missplaced it when I got my new computer.
