A/F Gauge pic
Posted: Thu Aug 18, 2005 6:46 am
by Merzbow
Here is a picture of the Air/Fuel gauge I bought. I have it wired to the side compartment until I get the other two gauges. Then I will mount them on the A-pillar or maybe in a different clever location if I can think of one.I might get the other two gauges in the Autometer Cobalt series instead of Sport Comp., because the Cobalt series are illuminated and I'm not sure if the Sport Comp. series gauges are.This is a picture of the gauge in action. For lal those that do not know, the gauge is constantly cycling from lean to stoich because of how the engine runs. If you are cruising at a certain rpm and let off the gas, it will sink into lean and then slowly fluctuate again. Of course when you floor it, the gauge will jump into Rich until you ease off the gas, in which it will go back to fluctuating.
Re: A/F Gauge pic (Merzbow)
Posted: Thu Aug 18, 2005 6:55 am
by BlueCrush
Cool! Are you able to close the little door with it in there as well?
Re: A/F Gauge pic (BlueCrush)
Posted: Thu Aug 18, 2005 7:37 am
by Merzbow
No, there's a plastic piece inside the dashboard thatprevents that... If I were to cut a hole in there it would work That's a good idea though!
Posted: Thu Aug 18, 2005 9:30 am
by scherry2
cool didn't someone put a gauge in the center air vent hole?that gauge would look cool there.
Re: A/F Gauge pic (scherry2)
Posted: Thu Aug 18, 2005 11:46 am
by Jahntassa
Quote, originally posted by scherry2 »cool didn't someone put a gauge in the center air vent hole?that gauge would look cool there.It was an oil pressure guage.. And I think the one he's got there is a bit too small for the vent. Though, I agree, that would look pretty cool!
Posted: Fri Aug 19, 2005 8:29 am
by McVibe
I like that gauge, the LEDs and whatnot, and yea, my gauge fluctuates all of the time, I have one with a needle and it gets pretty annoying when you are driving down the road at night and see this dancing light to your side.
Posted: Fri Aug 19, 2005 4:39 pm
by Lancer
Funny! I just installed one in my car, too. Getin' ready for the S/C install next weekend. I put mine in the center air vent. It looks really good in there! And the way I have it, you still get air out of it. The only bad thing was that while I was screwing on the nut to hold it on the vent screen, the nut slipped and rolled all the way down the air vent! Mine, though, at idle and when I let off the gas runs rich and runs lean on sight to full throttle.Did you all attach to the blue wire under the pass. carpet (second O2 sensor) or did you use the first O2 senser wire?
Re: A/F Gauge pic (Lancer)
Posted: Sat Aug 20, 2005 12:43 pm
by Merzbow
I used the sensor onthe header, so the first one. I connected it to the purple signal wire. The O2 sensor at the cat isn't strong enough I heard.
Posted: Sat Aug 20, 2005 1:03 pm
by damronjr
I'll be needing some assistance with this soon guys! Should be getting the SC in this week and hopefully installed shortly thereafter. How hard/easy was this to install? Where's a good place to get one?
Re: A/F Gauge pic (damronjr)
Posted: Sun Aug 21, 2005 6:25 am
by Merzbow
I bought mine from Jeff (Devlop) in the spring. on a scale of 1-10, 10 being the easiest, the install is probably a 8 or 9. I gues it depends on how steady your hands are while splicing the sensor signal wire..you can't cut it or it's bad news! then once you splice into there, you just need a positive and a ground and you're all set. I wired mine to the ignition so it turns on with the accesories...those digital multimeters come in handy.I would recomend Autometer, that's what I have. http://www.autometer.com shows you all the different styles. I personally like the "C2", "Lunar", and "Cobalt" series the best.
Posted: Sun Aug 21, 2005 7:31 am
by damronjr
I saw that site. They do have some nice guages. I was also looking at the boost guages for the SC but the ones they have are WAY too big in terms of units. They are almost all 0-35psi, where the SC will probably only need a 0-10 guage. They also didn't have prices.
Posted: Sun Aug 21, 2005 9:29 am
by Merzbow
That's a manufacturer's site that's why there are no prices...for some reason when you go to official websites they never post prices which irritates the hell outa me. I would say it would cost from $60-$90 for a gauge. If you want a pyrometer though those cost from $130-$200!!!
Posted: Sun Aug 21, 2005 10:52 am
by MadBill
Quote, originally posted by Lancer »Mine, though, at idle and when I let off the gas runs rich and runs lean on sight to full throttle.Did you all attach to the blue wire under the pass. carpet (second O2 sensor) or did you use the first O2 sensor wire? re O2 sensor readings:o The first, (upstream) sensor reading fluctuates, because for lowest emissions, the AFR is "dithered" by the ECU in a narrow range just lean and just rich of the stoichiometric (chemically correct) mixture.o Once the sensor is warmed up (normally less than a minute from cold), the engine runs in 'closed-loop' at idle and part throttle, using the signal to maintain the correct AFR as above.o Most engines run rich in open loop at WOT, for maximum power and piston/valve durability.o Common 'narrow band' sensors are only accurate in a narrow band near stoich. Mixtures leaner than ~14.9:1 or richer than ~14.5:1, produce very little change in signal and thus the gauge readings are somewhat questionable.o Some vehicles and some gauges use more expensive 'wide band' sensors which are extremely accurate from maybe 9:1 to as much as 40:1.o The second sensor (downstream of the cat or cats) is not used for engine control. Its purpose is to monitor the condition of the cat(s) for the OBDll-level diagnostics. A functional cat stores oxygen during the lean excursions noted above and releases it during the rich ones, thus the O2 signal is very steady. If the cat degrades and loses much of its chemical reaction-enhancing (emissions) capability, it also loses O2 storage capacity and so the second O2 sensor signal starts to fluctuate, alerting the ECU and setting a code.Bottom line: Something's wrong with your install, Lancer!
Re: A/F Gauge pic (MadBill)
Posted: Sun Aug 21, 2005 2:37 pm
by Merzbow
Well I did not know all that. Thanks for sharing! Now I can impress my friends lol j/k. I knew the O2 after/at the cat measured emissions that's why I used teh header.
Posted: Mon Aug 22, 2005 7:31 am
by george
Not sure i like the gauge in the left flip down console not very useful and hard to see i like the vent though looks good i did by an XM to fit my center console fits real nice besides what are you guys trying to monitor???
Re: A/F Gauge pic (george)
Posted: Mon Aug 22, 2005 7:44 am
by Merzbow
The reason i put mine in the left compartment is because I do not have the other two gauges im putting in yet so whats the point? I just hooked it up to hook it up and I hid it in the compartment so now one could see it until I get it up on the a-pillar.
Posted: Mon Aug 22, 2005 7:48 am
by AKLGT
yes, if i remember correctly, jeff installed his guage in the center air vent originally. it looked SWEET! man, it's a shame he had to get rid of all his turbo gear. but i'm sure the next time he does it, it'll be even better than the first!
Posted: Wed Aug 24, 2005 11:16 am
by Lancer
In that picture, the engine isn't running.But your saying I should use the O2 sensor on the header, right? I was wondering that and asked a few people and they all said to use the sensor closer to the exhaust. But I understand what you said and it makes sense. I'll try that this weekend after the new oil pan instal.Thanks MadBill!
