installation time?
Posted: Sun Aug 14, 2005 2:46 pm
by mcgusto82
for those of you savy guys. how long did it take you to install a S/C?better than average knowledge. i actually went to a auto mechanic school. ( did not finish)another quick question. a front mounted intercooler?? what do you guys think?
Posted: Mon Aug 15, 2005 11:21 am
by tangerine
front mounted intercooler is the best way to go
Re: (tangerine)
Posted: Mon Aug 15, 2005 3:27 pm
by Smokin' Rubber
Using a FMIC nearly impossible with the TRD eaton roots type supercharger due to how it is setup
Re: installation time? (mcgusto82)
Posted: Fri Aug 19, 2005 3:56 pm
by Lancer
I'll let you know when I install mine next weekend. I'll be taking some pics and painting some parts, though. So my total time will be off.
Posted: Sat Sep 10, 2005 2:58 pm
by Lancer
Ok, it's in and running, but not driving yet. I started at 6:30pm on Friday night and went until 12:30am. Got stuck on the fuel rail (POS). Took 3 trips to autozone trying to find the right tool that would fit. Finally went with the $10 plastic set. I'll return it on monday. Started today at noon and finally got the car running at 8pm. I took an hour or so to modify my CAI. Right now I'm a little hung up on where to connect the wires that run the servo on the throttle body of the s/c that run the 5th injector. I was going at a nice pace until the fuel line problem. Then it went down hill from there. Plus, I like to snoop around the parts I don't normaly get to see and then clean them!.
Re: installation time? (Lancer)
Posted: Sat Sep 10, 2005 3:43 pm
by damronjr
Dear God! It took Andre and I from about 8:30am - appr 2-2:30pm with a short lunch break, and that was including installing a boost gauge! I'm so glad I had him to help me, I would have taken a week and probably still screwed it up!
Re: installation time? (damronjr)
Posted: Sat Sep 10, 2005 4:45 pm
by Lancer
Got any pics of how you installed the boost gauge? I'd like to do that next weekend.
Posted: Sun Sep 11, 2005 5:19 am
by damronjr
Unfortunately he did it so fast I didn't even see it! One minute he was working on it and the next minute he was done! I hooked up the hose to the SC, but otherwise it's just 2 wires. You have to hook them up as the instructions should say and the hose goes through the firewall and into the sid eof the SC. IM me if you need help.
Posted: Sun Sep 11, 2005 7:35 am
by Lancer
But I have a TRD SC (and ecu) and I'm trying to connect it to the Unichip. Where do the servo wires for the 5th injector go?????
Posted: Sun Sep 11, 2005 7:57 am
by BlueCrush
Are you using the Unichip S/C harness to control the 5th injector?
Re: installation time? (BlueCrush)
Posted: Sun Sep 11, 2005 9:07 am
by Lancer
I told the chick at Unichip that I was gonna be upgrading to a s/c and header, she never mentioned anything about a special harness. So your saying I'm screwed by 3 little wires after a whole weekend of work.
Posted: Sun Sep 11, 2005 9:24 am
by BlueCrush
Umm, yeah. I would talk to Jack @ Unichip to get the correct set-up.
Re: costing for sc
Posted: Mon Sep 19, 2005 11:26 am
by aji2002
Jason; may know the cost for GM supercharger kit and is it can be purchased trough online order.I live in Malaysia and is it possible for me to get it. How abaout the fuel consumption after you instal the sc and how can you describe me the power of base vibe with sc. I am driving a toyota voltz built at the same factory as pontiac vibe by NUMMI for export market to asean country.
Re: costing for sc (aji2002)
Posted: Wed Sep 21, 2005 6:26 am
by satur9
if you have the gm ecu just hook that up till you get the right harness.i doubt your unichp is tuned for the supercharger if yo didnt get the harness they may have sent you a regular unichip. i would send it back just in case.. aslo to the voltz guy. id buy the trd supercharger for the matrix instead the toyota usually sells them for cheaper.(at least here in the states)than gm.
Re: costing for sc (satur9)
Posted: Sat Sep 24, 2005 4:34 pm
by Lancer
I said that I have the TRD s/c for my Vibe (TRD is not compatable with GM ECU) and I had the unichip for about a year already.But that doesn't matter now cause I'm finally all finished and boosted.
Posted: Sun Sep 25, 2005 10:00 am
by damronjr
Quote, originally posted by satur9 »aslo to the voltz guy. id buy the trd supercharger for the matrix instead the toyota usually sells them for cheaper.(at least here in the states)than gm.I agree. Another recommendation is to watch Ebay. Even Bluecrush is selling his right now, you would just have to get another ECU (i.e. Unichip or eManage).
