Non-working low beams
Posted: Sat Aug 13, 2005 1:33 am
by bluvibe
Last nite I discovered that my low beam headlights on my 03 are not working - had to drive home wit the driving lights. I checked the DRL fuse, which is OK, checked one of the bulbs, no evidence of it being burned out. I ollked at the headlight relay, but since it's sealed, I couldn't have seen anything. Any suggestions? Does the car have a sep. relay for hi/low beams?Thanks!
Re: Non-working low beams (bluvibe)
Posted: Sat Aug 13, 2005 4:18 am
Did you check the headlamp fuses under the hood?Have you done anything to the headlamp system lately that could have caused an overload?
Re: Non-working low beams (ragingfish)
Posted: Sat Aug 13, 2005 6:49 am
by redlava
The lights might have just simply burnt out. Try replacing them before you start tearing the car apart.
Posted: Sat Aug 13, 2005 7:05 am
He indicated the bulbs were not burnt out.
Re: (ragingfish)
Posted: Sat Aug 13, 2005 11:50 pm
by redlava
Whoops guess I should read a little more slowly.
