How does the GPS work
Posted: Tue Jun 18, 2002 2:30 am
by pimpingnu
I want to get the DVD nav system. Does it come with all the required DVD's needed to run it across the country? since it should contain the DVD codecs, would you be able to hook up an aftermarket roof mounted LCD screen and play DVD's? thanx
Re: How does the GPS work (pimpingnu)
Posted: Tue Jun 18, 2002 12:41 pm
by JDMstuff
The DVD navigation does not play normal DVD's. It is only a dvd-rom reader. The reason why they opted for the DVD is because DVD's have enough capacity to cover the entire country, so you don't have to switch discs while you're driving. There is no way for you playback DVD videos from the unit.
Re: How does the GPS work (JDMstuff)
Posted: Fri Jun 21, 2002 3:23 am
by MJN2
The navigation also covers Canada.
