HDTV tutorial
Posted: Thu Aug 11, 2005 9:17 pm
by Mr. Poopypants
OK, so, I just got a brand spankin new HTDV and I will be getting Comcast's HDTV box today (obviously, I have Comcast digital cable)If anyone has Comcast HD, what connection from the HD box to the TV? Does the HD box have an HDMI output?
Re: HDTV tutorial (Mr. Poopypants)
Posted: Thu Aug 11, 2005 9:27 pm
by JustinVGT
I have the Adelphia HD DVR and I connected it with a DVI connector. I don't know what Comcast uses, but I would think it would have a DVI or HDMI connection, in addition to an HD component output as well. If the digital connection isn't what your TV has, DVI or HDMI, you can buy adapters to change it to what you need. What kind of HD package does Comcast have? My only option is Adelphia or satellite and my Adpelphia HD selection is very limited. I get my local channels (FOX, ABC, NBC, CBS), a HBO HD, and a Starz HD channel. That is it. Is Comcast just as limited or do they have a better selection?
Re: HDTV tutorial (JustinVGT)
Posted: Thu Aug 11, 2005 9:43 pm
by Mr. Poopypants
My TV has HDMI and DVI connectors, from what I understand HDMI is the best quality, but I'm confused. I'm a nerd for electronics and stuff but the HD stuff is all new to me.Comcast has ESPNHD and DiscoveryHD as well as all the ones you listed, there are a few others, but I don't have the listing in front of me.Thanks for the input by the way.
Posted: Thu Aug 11, 2005 11:55 pm
by zionzr2
there is not much difference in video between DVI and HDMI however the HDMI carries an audio signal and DVI dose not!!
Re: (zionzr2)
Posted: Fri Aug 12, 2005 1:32 am
by Mr. Poopypants
Well, I just picked up the HD box on my lunch break and they gave me the component wires. I may just try those for now and maybe, if I'm feeling crazy I'll get the DVI. There is no HDMI coming out of the box, but my surround sound (coming next week) has the HDMI hookup so I may just wait until then.Thanks for the help.
Re: (Mr. Poopypants)
Posted: Fri Aug 12, 2005 2:18 am
by JustinVGT
I have both the component and DVI cables connected to my TV. When changing inputs, there isn't that much of a difference between the two. DVI is a little crisper since it's a digital connection, but it's not like it is a big, obvious difference. If you need a DVI or HDMI cable, definitely shop online. Most retail stores sell them way over priced. When I worked at Best Buy a couple years ago, the cables that cost around $100 were only around $30 at employee cost, which is 10% above cost.
Re: (JustinVGT)
Posted: Fri Aug 12, 2005 2:42 am
by Mr. Poopypants
I think I am going to get the DVI to HDMI cable. Since the screen is so big (61") a small difference on a smaller TV will be a big difference on a big TV. Now to order the NHL Center Ice package and sit around and watch some hockey (soon).
Posted: Fri Aug 12, 2005 3:00 am
by JustinVGT
Awesome, that is a huge screen! What kind of TV is it?
Posted: Fri Aug 12, 2005 3:17 am
by rasermon
I have a Samsung DLP TV and don't see any difference with the HDMI and DVI connectors. I use the HMDI for my Samsung Over-the-Air Digital TV Receiver and DVI to my Samsung HD-Conversion DVD Player. I"m just waiting for DISH Network. They will be moving to MPEG-4 Layer 10, H.264 (also called MPEG-4 AVC) compression for their HD channels. I been with Dish for 8 years now.
Re: (zionzr2)
Posted: Fri Aug 12, 2005 3:32 am
by millster
Quote, originally posted by zionzr2 »there is not much difference in video between DVI and HDMI however the HDMI carries an audio signal and DVI dose not!!Correct. There's actually no difference, technically. They're both a digital video carrier the primary difference is that HDMI also carries digital audio. Using DVI will require use of seperate analog audio unless your equipment is capable of digital audio via coax or TOSLink.My Toshiba only has the HDMI input. It's a 3-Gun projection though so I think that decision was made to keep people from plugging a computer in and burning the CRT's.OK, not that it really applied since Mr P has already stated that his box doesn't have HDMI, I just thought I'd throw that out there.
Re: (JustinVGT)
Posted: Fri Aug 12, 2005 4:20 am
by Mr. Poopypants
Quote, originally posted by JustinVGT »Awesome, that is a huge screen! What kind of TV is it?Samsung DLP
Re: (millster)
Posted: Fri Aug 12, 2005 4:22 am
by Mr. Poopypants
Quote, originally posted by millster »OK, not that it really applied since Mr P has already stated that his box doesn't have HDMI, I just thought I'd throw that out there. I am going to get a DVI to HDMI cable after work today and check it out. Hopefully, I have a few minutes to check out HD before I have to go meet with the priest. YIPEE..
Posted: Fri Aug 12, 2005 5:19 am
by rasermon
Quote, originally posted by Mr. Poopypants »Samsung DLPCool! I had mine for 10 months now and can't imagine going back to 27" tube. If you got the 61" I think it had a built-in HD tuner. I got the Samsung 46" DLP and at the time they didn't have the HD tuner. A month later I bought a HD Terrestrial Tuner. I'm sure yours looks similar to my small 46".
Posted: Fri Aug 12, 2005 5:58 am
by sloth
Quote, originally posted by Mr. Poopypants »Since the screen is so big (61")Husker games at Poopypants' house.!!!!
Re: (rasermon)
Posted: Fri Aug 12, 2005 7:33 am
by Mr. Poopypants
Quote, originally posted by rasermon » I'm sure yours looks similar to my small 46". It's the exact same design, I love it. Nothing beats Halo2 in HD.
Posted: Fri Aug 12, 2005 8:00 am
by millster
Quote, originally posted by Mr. Poopypants »It's the exact same design, I love it. Nothing beats Halo2 in HD.That's the one thing I wish I could do with mine. Picture quality with a CRT projection is stunning (provided you calibrate it right) but they just don't like computers.
Re: (rasermon)
Posted: Fri Aug 12, 2005 9:06 am
by Mr. Poopypants
Hey raser, got a question for ya. How do you get the non-hd channels to show up @ 16:9 aspect ratio? I cannot figure it out at all.
Re: (rasermon)
Posted: Fri Aug 12, 2005 10:36 am
by Toasted7
Toasted7 falls to the ground when he sees the pic of rasermon's HDTV!?! *thud*
Re: (Toasted7)
Posted: Fri Aug 12, 2005 11:20 am
by Mr. Poopypants
OK, I'll bite, here's mine. 56k bewarehttp://home.comcast.net/~m.fenton/100_0603.JPGAnd for comparison, here's me standing beside it. Yes I'm watching Elf.......This TV is Ginormous!!http://home.comcast.net/~m.fenton/100_0604.JPG
Re: (rasermon)
Posted: Fri Aug 12, 2005 2:22 pm
by binary
Ahhhh! Jeopardy in HD... now I can see how dumb I am in high def! Sweet!
Posted: Fri Aug 12, 2005 9:59 pm
by Mr. Poopypants
Quote, originally posted by Mr. Poopypants »OK, so, I just got a brand spankin new HTDV and I will be getting Comcast's HDTV box today (obviously, I have Comcast digital cable)If anyone has Comcast HD, what connection from the HD box to the TV? Does the HD box have an HDMI output?By the way to answer my orginal question and lend a helping hand to any other GenVibers who have Comcast and will be getting HD. The HD box that I got from Comcast has coax, component and DVI outputs.
