Installing Bumper Protector
Posted: Tue Aug 09, 2005 2:31 pm
by Vibetastic
Having read the instructions for installing the rear bumper protector, I see that I need 50/50 mixture of isylproyl alcohol and water and a 3 inch rubber roller.Where do I find a 3 inch roller? None of the hardware stores or paint shops in my area have such a tool.The alcohol is available as a 70 percent mixture, but the label does not state what the other 30 percent is. Is is water?Charles
Re: Installing Bumper Protector (Vibetastic)
Posted: Tue Aug 09, 2005 6:11 pm
by jwalcik
when i installed mine, i just gave my bumper a good scrubbing with warm soapy water (dish washing detergent), rinsed it, and dried it. then, after i placed it on the bumper, i pressed it down first with my hands, then with my knee and a towel to make sure it was firmly down. the adhesive is pretty strong stuff, so make sure you have it just where you want before putting any more pressure on it than you would with your hands.
Re: Installing Bumper Protector (jwalcik)
Posted: Wed Aug 10, 2005 2:07 am
by jeffgtx
i did the same thing as jwalcik, except i heated the bumper and the adheseive with a hair dryer. they recommended that when i installed my door sills and those things are ON good, so it kinda became supestition.
Posted: Wed Aug 10, 2005 4:14 am
by amhobby
I installed the Matrix protector on my Vibe and just cleaned it with alcohol, pushed it down and let it set in the sun. Piece of cake
Posted: Thu Aug 11, 2005 9:09 pm
by gregoire
I've ordered a bumper protector, but haven't received it yet.Is the adhesive already on the protector? if so, is it a "peel off" situation and then just press it on? or would I have to apply the adhesive?
Re: Installing Bumper Protector (gregoire)
Posted: Fri Aug 12, 2005 6:54 am
by jwalcik
there are two (three?) adhesive strips already on the bumper protector. you just peel off the wax paper to expose it.
