Cutting the cargo mat
Posted: Mon Dec 09, 2002 11:31 am
by vibegirl
Ok... I went to put the cargo mat in my Vibe and could not believe that it does not fit in when a child's car seat is bolted in. The safety belt bolts down on the hook in the hatch and this prevents the mat from lying flat ! Has anyone solved this problem? I plan on cutting a hole for it, but am concerned it will tear or fray. Most manufacturers have figured this out and have proceede to put the bolt down hooks on the back of the seat.
Re: Cutting the cargo mat (vibegirl)
Posted: Mon Dec 09, 2002 1:07 pm
by Flip-Side
quote: Most manufacturers have figured this out and have proceede to put the bolt down hooks on the back of the seat.Due to the fold-flat style seats and regulations on L.A.T.C.H. the seats in the vibe cannot support the anchor in an accident as well as one on the floor in the cargo area. I too have had this problem, and cut a hole in my rubber mat. If your liner has rubber backing, it shouldn't fray much if you cut a hole for the anchor.
Posted: Mon Dec 09, 2002 6:20 pm
by cohocarl
I bet if you just took a utility knife and made a slit in the exact area that the belt needs to go through, it may not leave a permanent hole when the seat belt is removed.
Re: Cutting the cargo mat (cohocarl)
Posted: Tue Dec 10, 2002 10:15 am
by baltimore17
Run a strip of duct tape across the back of the mat where you're about to cut the slit. Might keep the backing from fraying at least. You could also take the mat to a carpet store and they could bind the edges of the hole. Might cost some money, but would look real professional.
Posted: Tue Dec 10, 2002 2:31 pm
by vibegirl
Greta ideas! I'll let you know how it went.
