Dashboard rattles revisited
Posted: Sun Dec 08, 2002 3:54 am
by vibe owner
I've been chasing a dashboard vibration noise on my GT. Searching this forum and others, I come up with several possibilities including the instrument bezel, roof pillar, etc. Mine seems to be coming from very near (or inside) the gas gauge. I removed the instrument bezel and drove around a while, it still does it. The car must warm up a couple minutes (heat is on) and it happens most at around 2900 RPM but also sometimes up toward 4000 or as low as 1500. Accelerating seems worse than steady speed. The air vent near the A/C switch is an obvious suspect but touching it anywhere including inside the dash doesn't stop the noise. Any suggestions welcome -- I'll post updates at
http://vibeowner.home.attbi.com
Same here - i fixed the left round vent (near gas gauge) by wedging
Posted: Sun Dec 08, 2002 4:00 am
by RIT
some padding where the flex hose goes around the round outlet. Next I need to tackle the round vent near the temp gauge.
Re: Same here - i fixed the left round vent (near gas gauge) by wedging (RIT)
Posted: Mon Dec 09, 2002 12:35 am
by mkl116
Nobody has mentioned squeek in vent to left of steering wheel. I can't figure how to pull cover off to check it out. Pulls out a half inch or so but don't want to really pull and break something... If you have any ideas I'd like to hear them otherwise back to dealer I go....
Re: Squeaking coming from dash gauges...
Posted: Fri Dec 13, 2002 2:55 am
by VGTPILOT
Recently I've noticed an annoying squeaking coming from the dash. I finally isolated it to the gauge housings. If you grab them and push/pull around you can hear it. It looks like the plastic from the gauge housings is rubbing the plastic dash itself. Perhaps it's the cold weather but even when the inside warms up I hear it. I've had my Vibe since July and haven't noticed it. Anyone else had this problem?
Re: Same here - i fixed the left round vent (mkl116)
Posted: Fri Dec 13, 2002 3:29 am
by Frosty
quote:Nobody has mentioned squeek in vent to left of steering wheel. :rightarrow : I have something like that. I only happens when the car is cold. so it should fix itself in May. back to dealer I go.... I would like a dealer to check it out too, after christmas. Will let you know.
I found a major noise coming from the upper left stereo bolt that
Posted: Fri Dec 13, 2002 4:00 am
by RIT
had loosened over time. I had to remove the silver "surround" to get at it. The car is vault quiet now - sort of !
Re: Squeaking coming from dash gauges... (VGTPILOT)
Posted: Fri Dec 13, 2002 6:09 am
by NSimkins
quote:Recently I've noticed an annoying squeaking coming from the dash. I finally isolated it to the gauge housings. If you grab them and push/pull around you can hear it. It looks like the plastic from the gauge housings is rubbing the plastic dash itself. Perhaps it's the cold weather but even when the inside warms up I hear it. I've had my Vibe since July and haven't noticed it. Anyone else had this problem?Here is a thread with the solution to this squeak.. includes pictures:
http://forums.genvibe.com/zerothread?id=396
Re: Squeaking coming from dash gauges... (NSimkins)
Posted: Sat Dec 14, 2002 10:11 pm
by VGTPILOT
Thanks for the heads up. Actually after I posted this I dug a little deeper and found that tread myself. Hopefully I can get the dealer to fix this before X-mas. My dad works at that dealership so I'm counting on getting this taken care of asap. Thanks again! Andrew
