				Gauges installed
				Posted: Tue Jul 26, 2005 11:21 am
				by McVibe
				So I got around to installing my gauges today. I spent 7hours putting them in in 100 degree + weather. I actually enjoyed myself.   I'm not sure how but it was fun. But anyway I tried to make my own gauge pod using fiberglass, lets just say it looked like a piece of crap with three eyes and shaped it into a pillar  . Yea, so I removed the fiberglass and tommrow I'm going to hopefully cover the pillar in cloth or like foam and cloth. But anyway, I'll get some pics up. Also I have an issue that someone might be able to solve for me. My A/F ratio gauge looks like a cracked-out ADHD boy with sugar. The needle bounces all over the place when the car is just idoling.
				Re: Gauges installed (McVibe)
				Posted: Tue Jul 26, 2005 11:33 am
				by ColonelPanic
				I do recall seeing one on a GT at some point in time and it did bounce around a bit (but no too much) at idle.Where did you connect the sensor to?
				Re: Gauges installed (ColonelPanic)
				Posted: Tue Jul 26, 2005 11:37 am
				by McVibe
				The blue wire coming from the sensor on the exhaust mainfold.
				Posted: Tue Jul 26, 2005 11:47 am
				by ArcsVibe
				Have any pics?
				Re: Gauges installed (ArcsVibe)
				Posted: Tue Jul 26, 2005 12:05 pm
				by Psychobroker
				need pics please!
				Posted: Tue Jul 26, 2005 12:24 pm
				by McVibe
				I didn't really want to show any yet, it's very ugly because they're only installed and i havn't beautified them yet but here you go. I promise it will look better when I get some nice material on there, I would be cool to get rhino liner, but I don't think it's going to happen.
				Posted: Tue Jul 26, 2005 12:30 pm
				by BlueCrush
				Cool, nice to see that the gauges worked out.
				Re: Gauges installed (BlueCrush)
				Posted: Tue Jul 26, 2005 12:47 pm
				by McVibe
				I also had another issue, I can't get the gauges to dim correctly. I tried to hook them up to the dimmer switch but I thinkl I have them on the wrong wire so any help would be great.Quote, originally posted by BlueCrush »Cool, nice to see that the gauges worked out.Yea, thanks a load
				Posted: Thu Jul 28, 2005 6:45 am
				by Ponyota
				I'm interested in how you got the trim piece off. Can you post instructions on how you did that please?
				Posted: Thu Jul 28, 2005 7:23 am
				by zionzr2
				forgive my ignorence on this question but what does knowing the air/fuel position tell you???
				Re: Gauges installed (Ponyota)
				Posted: Thu Jul 28, 2005 9:34 pm
				by McVibe
				Ponyota: which trim piece do you mean, I basically had the remove them all to do this.zionzr2: The Air/Fuel Ratio gauge obviously monitors the Air/fuel Mixture present in your exhaust which it then gives you a read out if you are running lean(more air than fuel) Stoich(Good Mixture of fuel and Air) or Rich(More fuel than air).
				Posted: Thu Jul 28, 2005 10:53 pm
				by BlueCrush
				He's Talking about the A-Pillar piece. How did you remove that piece?
				Posted: Thu Jul 28, 2005 11:14 pm
				by nismo
				I would think that it's just clips that hold that piece on if I'm not mistaken.Inder
				Re: Gauges installed (TRD4reel)
				Posted: Thu Jul 28, 2005 11:23 pm
				by BlueCrush
				Check here:
http://forums.genvibe.com/zerothread?id=17920I attached a link there that will take you to MO for some examples of what they did on the Matrix.
				Posted: Fri Jul 29, 2005 4:15 am
				by McVibe
				Yea, ragingfish is right, only you do have to pull up on it a little bit once you yank it, as it is stuck in the dash.
