Allen wrench needed to remove the MAFS??
Posted: Mon Jul 25, 2005 1:46 am
by Psychobroker
None of my allen wrenches fit, so does anyone know the size needed? As for cleaning it, someone recommended spray carb cleaner, but the Gumout Carb & Choke cleaner I have contains petroleum -- wouldn't this pose a problem??EDIT: I believe Goodvibe made the spray carb cleaner recommendation (thanks)
Re: Allen wrench needed to remove the MAFS?? (Psychobroker)
Posted: Mon Jul 25, 2005 1:47 am
The MAF sensor? On the intake? That's phillips head dude.
Re: Allen wrench needed to remove the MAFS?? (ragingfish)
Posted: Mon Jul 25, 2005 1:49 am
by Psychobroker
Quote, originally posted by ragingfish »The MAF sensor? On the intake? That's phillips head dude. What?? Not mine...it's definitely not a phillips head..EDIT: Since it's bolted up to my AEM intake, I couldn't see the screws, so I used a little mirror just to check...and it's not a phillips head...
Posted: Mon Jul 25, 2005 1:58 am
Quote, originally posted by Psychobroker »What?? Not mine...it's definitely not a phillips head..EDIT: Since it's bolted up to my AEM intake, I couldn't see the screws, so I used a little mirror just to check...and it's not a phillips head...Really?!Odd. My two little screws are most definitely phillips. Not sure then.
Posted: Mon Jul 25, 2005 2:05 am
by Psychobroker
Crud. Thanks anyway Mike.
Posted: Mon Jul 25, 2005 2:27 am
by Mase
I have a spare AEM CAI for XRS at home. I can check the size after work unless someone posts up before me.
Re: Allen wrench needed to remove the MAFS?? (Mase)
Posted: Mon Jul 25, 2005 3:09 am
by Psychobroker
Thanks Mase, I was thinking maybe they were the screws that came with the intake. Of course, had *I* installed the intake myself, I would know the answer to this question .
Posted: Mon Jul 25, 2005 4:30 am
by drunkenmaxx
lets get this cleared up! my MPG isnt what i would like, so i prob need to do this too. (never have cleaned it @65k+)just spray the crap on and wipe?
Posted: Mon Jul 25, 2005 4:32 am
I bought a recharge kit at pep boys. You have to take off the filter, spray it out from the inside outward (to push any dirt off the filter instead of driving it in to the filter further), then use an oil based cleaner, spray it off, then put the filter oil on. give it a good day to do, and obviously, you can't drive the car without that filter on.
Re: (ragingfish)
Posted: Mon Jul 25, 2005 4:46 am
by drunkenmaxx
ATTENTION:we are talking about the MAF, not the filter!!
Re: (ragingfish)
Posted: Mon Jul 25, 2005 7:10 am
by Psychobroker
Quote, originally posted by ragingfish »I bought a recharge kit at pep boys. You have to take off the filter, spray it out from the inside outward (to push any dirt off the filter instead of driving it in to the filter further), then use an oil based cleaner, spray it off, then put the filter oil on. give it a good day to do, and obviously, you can't drive the car without that filter on.Yep, not worried about the filter, just the MAFS. I've read in one thread at matrixowners.com that using a Q-tip and rubbing alchohol is fine, while Goodvibes recommended a spray carb cleaner...I don't want to chance the latter since it contains petroleum (wouldn't this leave a residue?)
Re: (Psychobroker)
Posted: Thu Jul 28, 2005 5:45 am
by goodvibe
Sorry, I just got your message. I'll have to check my settings at home. The petrol in carb cleaner works as a solvent to wash away the oil by dilution. It then evaporates and leaves the surface pretty clean. Nonlubricating clear Contact cleaner, non residue brake cleaner etc. will also work, as I suppose would mineral spirits but the sprays are easier to use liberally. Acetone would be a bad choice. You can CAREFULLY whipe the excess fluid off and get an even cleaner surface.
Re: (goodvibe)
Posted: Thu Jul 28, 2005 8:00 am
by Psychobroker
Thanks for the feedback goodvibe . Now I'm just waiting for Mase to get back to me about his AEM CAI..Mase?
Re: (Psychobroker)
Posted: Thu Jul 28, 2005 8:59 am
by Mavrik
my MAF sensor has a philips head screw pattern to...
Re: (Psychobroker)
by Mase
OOPS! Sorry about leaving you hanging.9/64" (allen) is the size of the bolt head
Re: (Mase)
Posted: Fri Jul 29, 2005 7:19 am
by Psychobroker
Thanks Mase
