whats the difference
Posted: Mon Jul 18, 2005 8:45 am
by Stealth_Vibe
whats the difference between a short ram air intake and a cold air intake wich one is better and i also saw this on ebay its an electrical supercahrger intake whats that
http://cgi.ebay.com/ebaymotors...wItem
Re: whats the difference (Stealth_Vibe)
Posted: Mon Jul 18, 2005 9:59 am
short ram stops in the engine bay. your filter would land about where the stock airbox is now.cold air intake goes down into the lower fascia, and the filter lands right above the foglamp. cold air intakes tend to yield better results in terms of power gains and response...but the filter is much harder to access for maintenance.the electric supercharger is crap. stay away.
Posted: Tue Jul 19, 2005 5:26 am
by ToolGuy
Cold air is always better for an engine however you could I am sure get a shorty and run duct work from behind the fascia to the filter under the hood. Hydrolock would be less of an issue this way too. That is what I would do...Had to make a shield for my 1998 Z24 CAI from water. It too resided behind the front fascia. I took it off for the winters. using a shorty you will still see gains since you are eliminating all the stock restrictive duct work.
