what is double clutching
Posted: Wed Jul 06, 2005 12:18 pm
by platnum43
what is double clutching i heard of it before and how do you do it i spend to much time granny shiffting and need to learn how to double clutch if anybody has heard of it phrased that way
Re: what is double clutching (platnum43)
Posted: Wed Jul 06, 2005 12:35 pm
by ColonelPanic
I haven't got a clue about driving a manual but hey, I can google stuff. From http://www.standardshift.com/faq.htmlQuote »Double-ClutchingTruck transmissions don't have synchromesh gears which allow you to shift even if the input and output shafts are rotating at a different speed. For a truck, you need to match speed with what the engine and wheels are doing. Shifting for truckers is a two-step process. Hit the clutch and put the transmission in neutral. You then quickly tap the accelerator to match engine revs with what the wheels are doing, hit the clutch and put it in gear. You can use this method to see how smoothly you are shifting normally, and helps you learn how to rev match. The benefits of rev matching include smoother transitions between gears, especially on downshifts as well as reducing the wear and tear on the synchromesh gears themselves. Hopefully that is correct information. Sounds as if it applies to the big rigs but may be useful otherwise...
Re: what is double clutching (ColonelPanic)
Posted: Wed Jul 06, 2005 12:52 pm
by platnum43
thank you for your input
Posted: Wed Jul 06, 2005 8:37 pm
by goodvibe
Quote, originally posted by platnum43 »what is double clutching i heard of it before and how do you do it i spend to much time granny shiffting and need to learn how to double clutch if anybody has heard of it phrased that way A waist of time....in modern car trannys. That's what the synchros do for you. Takes longer than what you're doing now. To rev match on a downshift, just tap the gas when your moving the shifter to a lower gear while the clutch is depressed.
Posted: Wed Jul 06, 2005 9:32 pm
by binary
Quote, originally posted by platnum43 »what is double clutching i heard of it before and how do you do it i spend to much time granny shiffting and need to learn how to double clutch if anybody has heard of it phrased that way If you mean shifting without using the clutch - it's a lot easier on the vibes than many other cars/trucks I've driven. I ussualy only do it when I'm on driving around town and crusing... not on a highway merging Double clutching in a semi is why they seem to take forever to go through the gears... but they also get a lot more miles out of their transmissions than any of us would dream of.
Re: what is double clutching (binary)
Posted: Wed Jul 06, 2005 9:40 pm
by drunkenmaxx
double clutching is what you do instead of granny shifting, any real racer knows that.
Posted: Thu Jul 07, 2005 9:25 am
by tangerine
lol, platnum been watchin Fast and The Furious. Vin Desil told him he spent too much time granny shiftin and not double clutchin like he should have been. 'You never had me, and you never had you car!'
Re: (tangerine)
Posted: Fri Jul 08, 2005 4:16 am
by Emerica13
Double clutching is actually slower than 'granny shifting' too... and your car is only 170 hp not 180
Re: (Emerica13)
Posted: Fri Jul 08, 2005 4:24 am
by drunkenmaxx
Quote, originally posted by Emerica13 »and your car is only 170 hp not 180we should get that on some kind of auto reply!
Re: (drunkenvibe)
Posted: Fri Jul 08, 2005 6:00 am
by satur9
i actually double clutch often. it help when your tryng to go into second above 45 mph and stuff like that.instead of shocking the synchros and lurching.but yeah. clutch-neutral-rev-clutch-gear.
Re: (drunkenvibe)
Posted: Sun Jul 10, 2005 2:49 am
by Emerica13
Quote, originally posted by drunkenvibe »we should get that on some kind of auto reply! lol...down where the smileys are on the reply screen, have a button that says '170, not 180'
Posted: Sun Jul 10, 2005 2:53 am
by ragingfish
Quote, originally posted by binary »If you mean shifting without using the clutch - it's a lot easier on the vibes than many other cars/trucks I've driven. I ussualy only do it when I'm on driving around town and crusing... not on a highway merging Having never driven a manual transmission for more than say, 4/10th's of a mile, how does one shift without using the clutch???
Re: what is double clutching (ragingfish)
Posted: Sun Jul 10, 2005 2:55 am
by Emerica13
You can usually simply pull the shifter out of gear if the rpms arent too high, then just blip the gas and push on the shifter and let it drop into gear, takes a while to do right, and imo, not worth the risk of damage/embarassment of grinding gears
Posted: Tue Jul 19, 2005 2:38 pm
by jbrown
grip it and rip it!!
Re: (jbrown)
Posted: Tue Jul 19, 2005 2:56 pm
by binary
Quote, originally posted by jbrown »grip it and rip it!!Close, but only in a rental or loaner The Vibe's engine and tranny are pretty easy shift without pushing in the clutch. And you can really only do it in higher gears, you still need to feather the clutch when starting, or just dump it at 5k... whichever - you still need the clutch. Timing the shifting is the trick... I wouldn't recommend doing it on every shift - it can't be good for the tranny!
Re: (binary)
Posted: Tue Jul 19, 2005 3:18 pm
by 03VibeGT6Spd
Quote, originally posted by binary »Close, but only in a rental or loaner The Vibe's engine and tranny are pretty easy shift without pushing in the clutch. And you can really only do it in higher gears, you still need to feather the clutch when starting, or just dump it at 5k... whichever - you still need the clutch. Timing the shifting is the trick... I wouldn't recommend doing it on every shift - it can't be good for the tranny! For the past year I have only been floating my gear's trying to avoid wearing out my clutch.My clutch has only been used to start with or when racing.The Vibe is very easy to float because of there tapered gears.There is nothing wrong with floating gears, as long as your not grinding them. It'll save wear and tear on your clutch disk and throw out bearing as well as the wear on your transmission syncro's.
Posted: Tue Jul 19, 2005 9:19 pm
by ToolGuy
Normally on down shifts I ride out the current gear and when slow enough step in the clutch and go to neutral. When I do want to downshift I rev match. Step in the clutch, a little gas, choose the lower gear and release the clutch. Rev matches are better for the trans since you do not shock it by just throwing it down into the lower gear, better for the drive shaft too if RWD. You do not "jerk" the car by down shifting and rev matching, a smooth transition is what happens instead.
Re: what is double clutching (MiVibe-ToolGuy)
Posted: Wed Jul 20, 2005 1:43 am
by Psychobroker
Quote, originally posted by MiVibe-ToolGuy »Normally on down shifts I ride out the current gear and when slow enough step in the clutch and go to neutral. When I do want to downshift I rev match. Step in the clutch, a little gas, choose the lower gear and release the clutch. Rev matches are better for the trans since you do not shock it by just throwing it down into the lower gear, better for the drive shaft too if RWD. You do not "jerk" the car by down shifting and rev matching, a smooth transition is what happens instead. I've been doing this a lot more lately. The last thing I want is my synchros going out. Aren't the synchros what take the impact of an un-revmatched downshift?
Re: what is double clutching (Psychobroker)
Posted: Wed Jul 20, 2005 3:29 am
by ToolGuy
Not sure, this is the first manual I have actually ever owned. Maybe some one else can comment?I mostly rev match to smooth the transition into the lower gear, the engine likes it!
