A/C re-wire
Posted: Thu Jun 30, 2005 1:29 pm
by ychartra
Has anyone done this or does anyone know how to re-wire the air conditioner so the compressor is not engaged when the climate control system is set on defrost?
Re: A/C re-wire (ychartra)
Posted: Thu Jun 30, 2005 3:32 pm
by binary
Quote, originally posted by ychartra »Has anyone done this or does anyone know how to re-wire the air conditioner so the compressor is not engaged when the climate control system is set on defrost?Not sure the reason behind this?Defrost/Defog setting is supposed to remove moisture from the windshield, to do it effectively it runs the A/C unit to dry the incoming air. If I remember correctly - the ECU of the car will disable the A/C compressor when the outside temp is below a certain temp... I think it was in the lower 30's (f) but above freezing.I remember when my A/C stopped working - it took a lot longer in the fall/spring when it was very humid in the mornings and my windows were all fogged up.
Posted: Thu Jun 30, 2005 8:00 pm
from
http://forums.genvibe.com/zero...67743Quote, originally posted by ragingfish »There's a harness you can disconnect, but you have to pull out the climate control assembly from the dash...I really would advise against it, the compressor does make a difference...Anyway, should you decide to, here are instructions:
http://home.comcast.net/~vibeowner/buzz.htmStep 6 notes the harness to unplug.
