rear dif fluid change on my AWD
Posted: Thu Jun 30, 2005 12:33 am
by drunkenmaxx
how hard is it to do this yourself and what kind should i use. (not the most expensive, just what works)
Re: rear dif fluid change on my AWD (drunkenvibe)
Posted: Thu Jun 30, 2005 4:35 am
by bud_one
Rear Axle Housing Oil Capacity (Drain and Refill) 0.5 liters 1.05 pts Oil Recommended 80W-90 GL5 Lubricant GM P/N 12345977 (Canadian P/N 10953482) or the equivalentnow the actual - changing of the fluid I have to find out....
Re: rear dif fluid change on my AWD (bud_one)
Posted: Thu Jun 30, 2005 4:40 am
by drunkenmaxx
alright! a reply!!someone here must know how...
Posted: Thu Jun 30, 2005 4:44 am
The complex procedure
Attached files a040001.pdf (26.6 KB)
Posted: Thu Jun 30, 2005 4:46 am
the location of the drain and fill plugs is shown in this one somewhere
Attached files conponen.pdf (163.6 KB)
Re: rear dif fluid change on my AWD (joatmon)
Posted: Thu Jun 30, 2005 4:55 am
by drunkenmaxx
holy hell! thanks joat.
Posted: Thu Jun 30, 2005 11:16 am
by pmh013
Drunken, why are you changing your rear diff fluid? Did I scare ya?
Re: rear dif fluid change on my AWD (pmh013)
Posted: Thu Jun 30, 2005 9:35 pm
by drunkenmaxx
Quote, originally posted by pmh013 »Drunken, why are you changing your rear diff fluid? Did I scare ya?hows that?ive just been reading that you are supposed to change it, am i wrong? i have 63k miles on my car, i figured it was prob due. if not, then when should i??
Posted: Fri Jul 01, 2005 7:44 am
by pmh013
Yes, you are supposed to change it. I never changed mine, and last week (at 135,000 km/84000 mi) I just replaced the entire rear differential due to bearing failure.http://forums.genvibe.com/zerothread?id=17080
Posted: Tue Aug 23, 2005 5:48 pm
by Man of Steel
This looks rather easy. At how many miles should it be done?
Re: rear dif fluid change on my AWD (Man of Steel)
Posted: Mon Jan 02, 2006 12:33 pm
by brbo
Wow 80,000+ miles - the manual says every 24,000km / 15,000 miles (mines CDN) - I've only recently got my '06 AWD but I plan on doing it often being it's only for the cost of oil for me,,******Also take note you should be changing your tranfer case also - it takes the same type gear oil as the diff. The transfer case takes .75L and your rear diff is .5L so with a couple 1L bottles you have more than enough - I would also recommend changing it to Synthetic Oil for the small amount being used and the frequency of change why not have the best darn gear oil you can get,,,I've found BMW Motorcycle shops carry 80/90W Synthetic Gear oil for the shaft drive bikes and it's relatively cheap,,Lastly - if you buy the 1L bottles rather than a 4L jug it has a tappered filling neck that you cut open and if you are careful where you cut it and get 10" of clear tubing to fit in the diameter of the top Holes on the Diff and Tranfer case all you need to do is squeeze the bottle as it sits on the garage floor and the tube is inserted in the box being filled - pretty simple and clean process,, when it drips it's full,,Cheers,,B '06AWD
Attached files 2006PontiacVibeMaintenance.doc (158.5 KB)
