2zz Detailed Engine Specs?
Posted: Sun Dec 01, 2002 5:52 am
by a58vette
I am trying to configure the 2zz engine on my dyno software but it does not have the 2zz engine available. I already know the bore, stroke, and compression. But I need to know the camshaft details, wall thickness and other detailed information as such. If you have any information please let me know.
Re: 2zz Detailed Engine Specs? (a58vette)
Posted: Sun Dec 01, 2002 10:12 am
by d_m_kolb
1ZZ-FE info2ZZ-GE infoMMC All Aluminum Cylinder Block (2ZZ-GE)Camshafts and Rocker ArmsLeightweight Valvetrain componentsInfo provided from our friends at MatrixVibe.net
Posted: Mon Dec 02, 2002 6:21 am
by a58vette
Thats what I'm looking for. Thanks
Posted: Mon Feb 03, 2003 9:47 pm
by DABEAR95
I have tried switching everything into desktop dyno to simulate the power output, but it is difficult because I don't know the cam timing during lift. I just used the high lift cam numbers so I could look at the output over 6,000 RPM. I have the lift and duration but it still is not correct. I have to play around some more. I was able to model and play with my camaro engine successfully however.Jason
Re: 2zz Detailed Engine Specs? (Admin II)
Posted: Tue Feb 04, 2003 11:37 am
by MadBill
Hmm! Re above sites:1. The 1zz engine shown has an aluminum intake manifold, of a very different design than our plastic one. (Looks a lot like an early Oldsmobile Quad Four!)2. The power quoted for the 1zz in the chart on the 2zz engine report is 107 kW, or 143.4 HP....
