Subwoofer Question
Posted: Wed May 11, 2005 11:42 am
by VibeGT_2003
Is there a seperate amplifier running the sub? Or can I run a line converter to run a "Real Amp".
Re: Subwoofer Question (VibeGT_2003)
Posted: Wed May 11, 2005 11:51 am
by ragingfish
That's a good question...AFAIK, no one has yet to determine if there's a varying amp setup in the 05's with the sub or not. The question has been, whether the sub runs off the same amp (and if that amp is the same as the 03/04 MY amp), or if it runs straight off the radio...When you find out, report back!
Posted: Wed May 11, 2005 1:57 pm
by Jahntassa
I think someone said it was controlled by the M&T amp under the seat... If you can pull the sub out of the back, there should be probably something like two-five wires going to it. If there're two, you can run a line-converter off that, if there's more, you need to determine what's power and what's signal.I'm just guessing, I don't have an '05 or access to info to it..
Posted: Wed May 11, 2005 9:23 pm
by Mr. Poopypants
Quote, originally posted by VibeGT_2003 »Is there a seperate amplifier running the sub? Or can I run a line converter to run a "Real Amp".That is a good question, does anyone have a wiring schematic for the '05 M&T audio system?
Re: Subwoofer Question (ragingfish)
Posted: Thu May 12, 2005 1:14 am
by GMJAP
It runs off the factory amp under the passenger seat. I'll try to remember to post a schematic when I get home.
Posted: Thu May 12, 2005 9:34 am
by GMJAP
Schematics for M&Ts radio, amp, speakers, and woofer.
Attached files AmpSch.zip (311.5 KB)
Re: Subwoofer Question (GMJAP)
Posted: Thu May 12, 2005 1:20 pm
by scherry2
Quote, originally posted by GMJAP »Schematics for M&Ts radio, amp, speakers, and woofer.Hmmm my computer says your file is corrupt.
