Another AUX2Car install sucess
Posted: Sat May 07, 2005 1:50 am
by 04kvibe
Just got the adapter installed...works great, easy install (thanks to my hubby) for those who don't want to replace the HU. Just for clarification I have an 04 with the single disc & M&T.Thanks to all who posted info and how to's on this product. Couldn't (wouldn't) have done it without you. Here's the link for the adapter.. http://www.discountcarstereo.c...D=749Product ID: PXDX Product Name: Peripherals AUX2Car Auxiliary Input Adapter with Free Cable. Price: $75.98 Select Cable - PXHGM3 Vehicle Year/Make/Model - Vehicle Year/Make/Model 04 Pontiac Vibe Best price you'll probably find, $84.46 with the shipping... ordered on Tuesday evening...arrived in the mail Friday.Now, if my new Rio Carbon worked...but that's another story
Posted: Sat May 07, 2005 1:56 am
by remusrm
i will order this too... today... kind of worried, since i got the 6 cd in dash...
Re: (remusrm)
Posted: Sat May 07, 2005 2:20 am
by 04kvibe
I think the jury is still out on whether this will work with the in dash changer.Just to be sure, I would wait till Monday to call and ask unless you can get a definitive answer from someone here. just my opinion
Re: (04kvibe)
Posted: Sat May 07, 2005 7:51 am
by benwellington
I want to know too! I called and they said it would work fine with the indash changer on the 2005 vibe. You just hook it up to the 12 pin in the back.But I am waiting for confirmation before I buy it too.
Posted: Sat May 07, 2005 11:12 am
by Jahntassa
Do you have XM, Onstar on your '05? It's possible that you might have to disconnect and/or lose functionality of one or both.Just a warning..this is uncharted territory, so please let us know how it works out with the 6-disc!
Re: (remusrm)
Posted: Sat May 07, 2005 11:28 am
by GMJAP
Quote, originally posted by remusrm »i will order this too... today... kind of worried, since i got the 6 cd in dash...I hate to ruin the party, but it won't work on the 6CD.(Unless you somehow got one with a BAND button. And if so, I really want to talk to you!)That's a definitive answer. I've tried it.
Re: Another AUX2Car install sucess (04kvibe)
Posted: Sat May 07, 2005 1:48 pm
by dan326
Where is the power wire hooked up on your aux2car adapter?
Re: Another AUX2Car install sucess (dan326)
Posted: Sat May 07, 2005 11:46 pm
by 04kvibe
to the blue wire w/ white stripe in the radio harness...I'm glad we got the in dash 6 CD problem answered...sorry guys
Posted: Sun May 08, 2005 12:19 am
by dan326
Did your adapter harness have just one yellow power wire or was there a ground wire coming out of the harness as well?
Posted: Sun May 08, 2005 3:26 am
by GMJAP
Mine had just the yellow power wire. It grounds through the radio 12-pin
Posted: Sun May 08, 2005 8:39 am
by remusrm
so this will not do anything for me since i got the 6 cd in dash, no band button and also no xm/nav...
Re: Another AUX2Car install sucess (GMJAP)
Posted: Sun May 08, 2005 11:14 am
by dan326
Where did you connect your power wire? No ground loop and alternator whine for you?
Re: (remusrm)
Posted: Sun May 08, 2005 1:04 pm
by GMJAP
Quote, originally posted by remusrm »so this will not do anything for me since i got the 6 cd in dash, no band button and also no xm/nav...Unfortunately, correct.Quote, originally posted by dan326 »Where did you connect your power wire? No ground loop and alternator whine for you?Answered this in your thread. Briefly: to 24-pin Blu/Yel
Posted: Mon May 09, 2005 10:42 am
by kcinmi
Sounds like she tapped into the blue wire with a white strip, constant 12 volts to the radio. Thats the same place I tapped into, no whine or noise of any sort. I do wonder, if anyone may be able to answer, instead of tapping into constant 12 volts, why not tap into switched 12 volts? I wonder if it would do away with the white noise I get after I shut everything off?
Posted: Mon May 09, 2005 11:20 am
by Jahntassa
Depends on what the adapter needs. If there're any settings it has to store or anything, having the constant power switch on and off might cause problems down the line. I doubt it would have anything to do with the 'white noise'.. Especially if the radio is off. But..who knows for sure..
Re: Another AUX2Car install sucess (kcinmi)
Posted: Tue May 10, 2005 9:51 am
by 04kvibe
Yup, that's where it is, haven't heard any noises...The little I have used it anyway. I bought to use with an mp3 player, got a 5 gig Rio Carbon...it had issues had to take it back.I have a Zen Micro on order from Circuit City, should be here by the end of the week, can't wait
