Anyone here in TORONTO know where I can pick up a MAF without having to wait for an order?
Posted: Fri May 06, 2005 11:03 am
by CyBeRjUnKiE
Anyone here know where I can pick up a MAF? I was thinking of going to Toyota to see if they carry the part. Can anyone help? If someone can also provide the part number for it as well. I have Base Vibe Manual Transmission. I screwed up my MAF today and can't get the car to REV higher than 3000. Will the part number be different from the Matrix? And I can use the Matrix MAF since the engines are identical will it be model specific?Thanks in advance!!!
Posted: Fri May 06, 2005 11:12 am
by AKLGT
how did you mess up your MAF? installing an intake? if so, then put the stock air box back in and take it to the dealership. they should be able to replace it. otherwise, you'll be on a waiting list most likely and pay $$$
Posted: Fri May 06, 2005 3:20 pm
by ragingfish
I doubt a MAF is a stocked part anywhere. Sorry, but I doubt you'll have any choice but to wait for an order. Unless you have a junker nearby or something...
Re: Anyone here in TORONTO know where I can pick up a MAF without having ... (silverawd26)
Posted: Fri May 06, 2005 4:02 pm
by Mavrik
when I accidently blew mine I had it covered under warranty by putting my stock airbox back in and the intake taken out before I limped the car in. They didn't have one on hand either so I was able to take it out of the 05 sitting on the lot and when the ordered one came in, it went on the 05 Vibe. Maybe they can do something like that for you.
Re: Anyone here in TORONTO know where I can pick up a MAF without having ... (Mavrik)
Posted: Fri May 06, 2005 9:33 pm
by CyBeRjUnKiE
Would anyone here then have a walk through in reversing the installation and installing the Stock Air Box? My car is still under warranty, in fact I'm supposed to bring the car in this Monday to have my clutch replaced under warranty. I could use the help to reverse all this now so that I can bring it all together and tell them my car broke down.
Posted: Sat May 07, 2005 12:41 am
by CyBeRjUnKiE
Thanks everyone, I finally found a dealer that carried it. Toytota downtown on front street carried the part. Pretty expensive part as well since it cost me 240 with the taxes included. It's 211 before taxes. Anyways, the car seems to be back to normal. I'll have to wait for this Monday for my clutch to be replaced under warranty of course. Whew, I'm glad to know that my MAF is back on fine now though. I think I screwed up my MAF because I didn't take out the battery first. But even before I took it out, my car was acting weird, and I suspected it was the MAF. Although I was still reving higher than 3000. Anyways, I'll keep my fingers crossed and hope that everything is okay now. Thanks everyone!
Re: (silverawd26)
Posted: Sat May 07, 2005 1:56 am
by CyBeRjUnKiE
Well, I had two options....leave the car as it was and put the old Air Box inside, or just buy the darn thing. If I still experience problems then I'll probably put the Air Box in and have them test out what's wrong with the car. I'm pretty sure that it's not the MAF now that it's got a brand spanking new one. I'm still getting some stuttering on my car, I think it's my Clutch slipping though, well I hope that's the case, I guess I'll find out after this monday.
Re: (CyBeRjUnKiE)
Posted: Sun May 08, 2005 11:00 pm
by CyBeRjUnKiE
It seems, I'm back in limbo. CEL light came back on after several kilometers and the car is putt putting now as a result of it. MAF is working since I'm able to rev over 3000 RPM. But I hear this loud ticking sound near the MAF, which looks like some valve. Not sure if it's supposed to tick that way or not. Anyways, I've put the stock air box back in, and brought it in today for servicing. Clutch is getting replaced under warranty as well as the bearing, and I've asked them to look into the engine. CEL wasn't on this morning since I've put the stock air box back in, but it was still putt putting and sounding really nasty when I reved up. I'm starting to get really discouraged since I'm getting this feeling that I'm going to be coughing up some dough for this car which is only 2 1/2 years old. I'm hoping that these guys fix the car up, but even when they do, I think I'm going to feel very uneasy taking it for long trips. What a bummer....hopefully things will turn a lot better when I pick up the car today. But I'm not having my hopes up too high.Will keep you guys posted.
Re: (CyBeRjUnKiE)
Posted: Mon May 09, 2005 2:27 am
by Mavrik
Well hopefully everything works out. Only ticking sound I ever heard was on the wife's Vibe GT and she was always told it was normal. Since my Vibe is a base, I've never heard it, What model is yours?
Re: (Mavrik)
Posted: Mon May 09, 2005 3:55 am
by CyBeRjUnKiE
I have the 2003 Base Vibe. I'm hoping that the ticking sound is normal. I'm keeping my fingers crossed and hoping that the car is okay. Considering it is going through a clutch replacement, I'm a little skeptical of the outcome. Anyways, to think on the positive side, at least I've got a new clutch. As for the ticking noise....it's coming from the valve that's close to the green EVAP knob. Not sure if that makes any sense to you, but it's the one with the blue plug near the MAF sensor. I don't know if the ticking sound has anything to do with the problems I'm having. All I know now is that my car is getting crappy results regarding to power. I've got to rev up my car to get a decent startup on 1st gear, and the REV doesn't even sound smooth...sounds like it's putt putting until I reach 3000 and higher. Argghhh....I hope all is well...in the meantime, I'll just have to wait to find out what the diagnostic will be. I've read somewhere that it might be the EVAP system, if so I hope these guys at the dealership will see it on the OBD2 reader. Wish me luck!!!
Re: (CyBeRjUnKiE)
Posted: Tue Jun 21, 2005 2:34 pm
by rated_w
my maf sensor blew a few weeks ago... couldn't rev over 3000 easily.. but still went a bit over.. MAF sensor is a common problem for the 1ZZ engines.. just hope it doesn't effect vibes/matrixes or the new corollas.this past year dixie toyota has sold over 300 MAF sensors for this prob.I got mine replaced.. 361 after everything.. diagnosis.. part and installation.. geeze.. mommy demanded to let them do it cause she's afraid that I don't know what I'm doing....
Re: Anyone here in TORONTO know where I can pick up a MAF without having ... (CyBeRjUnKiE)
Posted: Tue Jun 21, 2005 7:57 pm
by cohocarl
I know it wouldn't have anything to do with the valve you are hearing, but hasn't there been a few people here with clogged cats?
Re: Anyone here in TORONTO know where I can pick up a MAF without having ... (cohocarl)
Posted: Tue Jul 26, 2005 9:38 am
by Psychobroker
Did you disco the neg batt terminal before installing it? Did you also allow it to idle for approx 10 mins after installing it?
