FOG LAMP protectors for sale
ToolGuy
Post by ToolGuy »
NEW ONE TIME Guarantee: For anyone that has bought my covers, I will now give you one (1) lens free lens replacement. If one, (1) not both is ever lost, one time during yoiur ownership just IM or email me. I have made well over 100+ sets of lenses now and my costs are covered to cover one, once for people for free. Plus my days are numbered since I am pretty sure the 2009 Vibe has plastic fog lamps...Again though, this is a one time, one cover only guarantee...I have decided to make and sell these and a couple of great members helped my decision too! My kit is a low cost answer to the dreaded cracked/broken glass fog lamp lens on our vehicles usually caused by rocks.They are plastic Lexan protectors 2.3mm thick, that adhere to the face of the fog lamp. The covers can be removed to clean and are not permanent mounts. The covers will not burn out bulbs; the heat can still dissipate. The prototype set on my car and the one used in the pics has been on the car for three and a half years now and through three Michigan winters. (updated 2-14-08) My fog lamps are on each and every time the headlamps come on as well. You can see pits already on the Lexan from the below prototype pic; means they are doing their job. The Lexan is crystal clear when new. NOTE: The lenses have gotten improved shape wise, since my pic below since those were the prototypes. I figured better to take a pic of a tested set then not... They have not been tested on HID bulbs.Each kit is hand made and made to order. Meaning you IM or email me, I make your set, email you back THAN you pay me and I ship. That way you do not pay me and wait and I do not get stuck with inventory. I can take Pay Pal, Cashiers Check or Money Order.Each 2 lens kit and detailed no tools required instructions sells for $25.00 USD TOTAL shipping INCLUDED (US or Canada)...FYI, one new Fog Lamp costs $140.00+ for our cars...Here is a pic of a clear set...
ToolGuy
Re: FOG LAMP protectors for sale (MiVibe-ToolGuy)
Post by ToolGuy »
An after pic...
tnpartsguy
Post by tnpartsguy »
I've test fit mine, they look great, havn't installed them yet due to weather (wet and crappy). I wish you could make a shield for the whole front end...LOL
Ponyota
Post by Ponyota »
Can you make them in smoke color like the overlays?
Click on signature to view Ponyota on cardomain
ToolGuy
Re: FOG LAMP protectors for sale (Ponyota)
Post by ToolGuy »
Quote, originally posted by Ponyota »Can you make them in smoke color like the overlays?I have not been able to locate smoked Lexan yet. However the overlays should stick to them and OR they may be able to be painted with translucent paint if lightly scuffed. Not sure though never tested it... Normal smoked plexi will surely crack and shatter though, I will keep searching for smoked Lexan.
ToolGuy
Re: FOG LAMP protectors for sale (silverawd26)
Post by ToolGuy »
Quote, originally posted by silverawd26 »Tool- They will fit the Matrix's, same foglight and I have to tell you first hand, this is a great idea. Thanks for the info and thanks for the compliment, I really appreciate it!!!!!
jtodd
Post by jtodd »
Here's a big for this product. I've had mine for a while now, and the fit great , the velcro shows very, very little, and they protect those $100 + fog lights perfectly. I've even forgot to take mine off at the no-touch carwash and they stayed on with no problems!!! If you haven't bought these yet, you sure will after you break your first fog lens!!Jeff ToddJackson, MI
'04 Base Vibe,Lava Two-tone,OBX Carbon fiber shifter,AutoVentshade Hood Protector,Fog Lamp Protectors by Todd Maar(MIVibe-ToolGuy),Tinted, Abyss Top Spoiler, GM exhaust tip
ArcsVibe
Post by ArcsVibe »
I want one
Genvibe Global Moderator
MOTM September 06 & July 09
VOTM April 06
Matrix XR 2010 (5-09-2014)
Ponyota
Post by Ponyota »
Quote, originally posted by MiVibe-ToolGuy »I have not been able to locate smoked Lexan yet. However the overlays should stick to them and OR they may be able to be painted with translucent paint if lightly scuffed. Not sure though never tested it... Normal smoked plexi will surely crack and shatter though, I will keep searching for smoked Lexan. A little tech insight....Lexan polycarbonate is one of the most widely known "plastics". Lexan sheet with its unique combination of high impact strength, flame retardants, and thermoformability makes it ideally suited for security applications. No other plastic can match Lexan's combination of light transmittance (clarity), and the ability to withstand extreme impact. In thicknesses of .125", Lexan 9034 sheet will transmit 86% of the light. Lexan 9034 is UV stabilized, has a heat deflection temperature of 270 degrees F at 264 PSI, and has a smoke density rating less than 75. If your thinking, "will this stuff hold up?" You better believe it will! My brother and I had lexan windows all the way around our drag car and never had it chip or crack. Another little tidbit of info is, you can polish out the scratches that can happen over time without turning the lens white with scuffs. I've done it to the drag cars front window twice and it looked like new. The only reason we had to do it was because of night racing and the lights that reflected within the spider web scratches that occur over time with washing and wiping. We didn't need the distraction and needed the clear view of the track ahead. If I remember right, there is a specific polish for lexan. MiVibe-ToolGuy, I've also learned that in addition to colorless (clear), Lexan 9034 is available in solar gray and bronze in thicknesses from .080" to .500". Though I'm not sure if you can get it in your local area or not.
ToolGuy
Post by ToolGuy »
Thanks Ponyota I appreciate that! I knew some of that but not all. Before I started selling I used a hammer and hit the Lexan just to see how it would react. No cracks or breakage, just dents and bending. I even took a lighter to it to observe its burning properties.
ArcsVibe
Post by ArcsVibe »
I got mine as well and were a snap to install. Thanks again Tool for the rapid shipping.He even includes a colour installation booklet Thanks again
VOTM April 06
21Rouge
Re: FOG LAMP protectors for sale (ArcsVibe)
Post by 21Rouge »
Quote, originally posted by ArcsVibe »I got mine as well and were a snap to install. Thanks again Todd for the rapid shipping.He even includes a colour installation booklet Thanks again I should have piped in sooner. I *think* I was the *first* Cdn to take delivery of this very useful 'mod' . Todd made sure shipping was painless and he provided 24 hour technical support for qs regarding installation . I highly recommend
ArcsVibe
Re: FOG LAMP protectors for sale (Boxgrover)
Post by ArcsVibe »
They are super sweet! Look good too. Thanks Tool Here they are on my Vibe:
VOTM April 06
ArcsVibe
Post by ArcsVibe »
Free bump for a worthwhile product!
VOTM April 06
Toasted7
Post by Toasted7 »
Looks like a good idea! Might have to order some of those myself... I know I don't want to crack a fog light cover.
ToolGuy
Re: FOG LAMP protectors for sale (Toasted7)
Post by ToolGuy »
Anyway sure beats the over $100 to replace one fog lamp new! I am currently making a new set for my car (red) above since the pic is the prototype set.
drunkenmaxx
Post by drunkenmaxx »
Quote, originally posted by silverawd26 »You keep the Mags right? yeah, no kidding!! unless of course, he doesnt like boobs...
drunkenmaxx
playboy...come for the boobs, stay for the articles!
merckx56
Re: FOG LAMP protectors for sale (drunkenvibe)
Post by merckx56 »
Or you can put Lamin-X on them, and it comes in different colors...
2004 Vibe GT 6 speed2006 Ridley DamoclesMen have three basic needs...eating, sleeping, and (removed), and I can do all three in my car...by myself!!!
merckx56
Post by merckx56 »
http://www.lamin-x.comI did yellow, but it comes in smoked and blue (HID-look) too! Fogs look good with the yellow!
ArcsVibe
Re: FOG LAMP protectors for sale (merckx56)
Post by ArcsVibe »
Tool Guy any chance of getting them in blue?BTW the ones I have on now are just awesome
VOTM April 06
ToolGuy
Post by ToolGuy »
Sold the first set on eBay! EDIT: here is the closed auction link...http://cgi.ebay.com/ebaymotors...42611I would like to take the time and thank the following people on making this a successSamDougRichardJeffJamesGodMy mom and dadMy managerLOL!!!! OK not those last three but the first five for sure! Thanks for the support and valuable feedback!
ArcsVibe
Post by ArcsVibe »
Always here to help out a fellow member Toolguy
VOTM April 06
ArcsVibe
Post by ArcsVibe »
Free bump for toolguy!Come on peeps lets encourage our fellow genviber here! His item is really worth it!
VOTM April 06
ArcsVibe
Post by ArcsVibe »
NOW AVAILABLE IN COLOR!!Check out the latest creation by our own Mivibe-Toolguy Last but not least the nighttime shot Thanks again Todd they are wicked! Come on guys encourage one of our own Great guy, fantastic first rate quality item here
VOTM April 06
tnpartsguy
I'm actually taking mine to the OH meet to install again. I took them off to clean them, and decided to use a different kind of Velcro than I used the 1st time. (I ordered mine without any, so I could play with some of the newer stuff I had here)
ToolGuy
Post by ToolGuy »
EDIT 3/20/06: The only color I can do is:YellowThe price for a colored pair is $35.00 shipped. More steps are involved to make these over the clear as well as 4-5 coats of translucent paint. You forgot this pic Sam!
ArcsVibe
Post by ArcsVibe »
Oops sorry about omitting that picture Todd
VOTM April 06
ToolGuy
Re: (tnpartsguy)
Post by ToolGuy »
Cool! Let me know if you need anything and if you get asked what are those, you know what to tell them!
ToolGuy
Re: (MiVibe-ToolGuy)
Post by ToolGuy »
Winter is coming for some, better get your car ready now! All new Gen Vibers please check out my product... (bump for new-bees)
heha
Post by heha »
does the light get duller with the colored covers? those blue ones look awesome.
sometimes madness is confused with passion.......but is there any other way to live?
AzFusionGT
Re: (heha)
Post by AzFusionGT »
I want a set! PM sent.
2006 Saturn Vue Red Line -A Moose is on the Loose-1990 Toyota Camry LE-V6 - Katy the Camry -
ToolGuy
Re: (heha)
Post by ToolGuy »
Quote, originally posted by heha »does the light get duller with the colored covers? those blue ones look awesome.Yes the color does dull a little bit... However the set pic'ed in blue has 4-5 coats of paint on them. 4-5 coats is more for "look" than function.I am in the process of sending a set with only 2-3 coats of blue on them. This should yield more usable light due to less paint used.Arcsvibe will probably post new pics with these covers when he receives them...At any rate I can do light or dark coverage of paint depending on what someone would want.I am doing a dark red pair now...
ToolGuy
Post by ToolGuy »
Here is something I found on ebay. Think my covers may be out of your price range, look at this.http://cgi.ebay.com/ebaymotors...ZWD1VBoth products have their pros and cons, however besides the price of $54.00 for the above, my lenses are 2.3mm thick. The ebay auction is 24mil thick compared to my 2.2MM. Mil & mm are two different measurements, mm being thicker.Not knocking these, just comparing...
ArcsVibe
Post by ArcsVibe »
Can't wait to test those bro!
VOTM April 06
Vibedad
Post by Vibedad »
Just ordered mine guys!Will post some pics when done!
Vibedad 2005 Base Vibe, Abyss, 5 spd, Moons & Tunes, all options but leather, Tinted, Cosmo CAI, Megan STB, Tein S Lowered
ArcsVibe
Post by ArcsVibe »
Quote, originally posted by MiVibe-ToolGuy »Arcsvibe will probably post new pics with these covers when he receives them...At any rate I can do light or dark coverage of paint depending on what someone would want.I am doing a dark red pair now...Here is a great pic of the new fogs. They are amazing! The fogs are much brighter and have a nice hint of blue tint in the lights.
VOTM April 06
POLO
Re: (ArcsVibe)
Post by POLO »
I wanted one But,i see a little green reflect too.Sam,can you put a pic in day light too.
Re: (ArcsVibe)
That really does look good, guys! That's quite a nice product, Toolguy.
Flip-Side
Post by Flip-Side »
I have not had a problem with my fogs yet, but who knows. They look pretty good bro.
Cougar Vibe
Post by Cougar Vibe »
I got my clear covers this past week and I'm very happy with them...now if that Vibe CarBra would just get here soon.
ToolGuy
Re: (Cougar Vibe)
Post by ToolGuy »
Great and thank you! If you have any issues do not hesitate to ask!
ToolGuy
Re: (ArcsVibe)
Post by ToolGuy »
Quote, originally posted by ArcsVibe »Here is a great pic of the new fogs. They are amazing! The fogs are much brighter and have a nice hint of blue tint in the lights.Just saw this today, thanks Sam! They look great! There is another member here with RED, possibly he will post pics. His are deep red, that is the way he wanted them!
ToolGuy
Re: (ColonelPanic)
Post by ToolGuy »
Quote, originally posted by ColonelPanic »That really does look good, guys! That's quite a nice product, Toolguy. CP your yellow are sprayed and waiting to for me to finish and ship as we speak! They look great too, not too dark! When I get back from WI I will mail them. Later this week...
ToolGuy
Re: FOG LAMP protectors for sale (Flip-Side)
Post by ToolGuy »
Quote, originally posted by Flip-Side »I have not had a problem with my fogs yet, but who knows. They look pretty good bro. Thank you!
Shadow-Vibe
Post by Shadow-Vibe »
Does anyone have a pic of these in red? I'd like to see what they look like!!
djpositivek
Re: FOG LAMP protectors for sale (Shadow-Vibe)
Post by djpositivek »
You should get these smoke colored to match your headlight covers. That's probably what I would do.
Abyss 2005 FWD 5 speedDe-badged
ToolGuy
Post by ToolGuy »
Here is my car with the red lenses held up to my current clear. I did not fastened since they were for a customer and sold.
ToolGuy
Post by ToolGuy »
another red pic...
ToolGuy
Post by ToolGuy »
last red pic, these are the only I had. None on the road since again, they were sold...
