Vacuuming
Posted: Mon Apr 18, 2005 10:26 am
by POLO
Last summer i bought this vacuum 12V battery ,very portable,powerful...http://www.canadiantire.ca/(removed)...=trueBut after a hour of vacumming the car,the battery start low,so he lost it``s power.So,now i wonder if it`s not more good to have with cordon,have power anytime,so i wonder if this it`s ok.http://www.canadiantire.ca/(removed)...l.jsp
Re: Vacuuming (POLO)
Posted: Mon Apr 18, 2005 10:36 am
by Kari
Well, any vacuum that you can get in the car and work with in the car will work, really... But if your question is about whether or not you can plug the vacuum into the household outlet in the dash and run it off of that, then it won't work, because it just draws too much power. This was one of the things I wanted to use my household outlet for, but unfortunately, it doesn't work.
Posted: Wed Apr 20, 2005 1:38 am
by Stang2Vibe
I like to use a shop-vac on car interiors. It can suck most of the sand and fine dirt out of the carpets and the attachments help to clean out the hard-to-reach places. LOTS of power from a shop-vac!
Posted: Wed Apr 20, 2005 4:25 am
by Mr. Poopypants
I have the corded version of that shark vaccuum, it works out much better than battery powered ones. I would recommend the one I have.
Re: Vacuuming (Mr. Poopypants)
Posted: Thu Apr 21, 2005 3:52 am
by drunkenmaxx
those corded sharks have some (removed) behind them!! they move when you first turn them on because of the circular motion!!
Re: Vacuuming (drunkenvibe)
Posted: Thu Apr 21, 2005 10:23 pm
by Mr. Poopypants
Quote, originally posted by drunkenvibe »those corded sharks have some (removed) behind them!! they move when you first turn them on because of the circular motion!!That's what I'm talkin about.
Posted: Sun Apr 24, 2005 12:06 pm
by DaddyVibeMI
I have to go to my parents house to use their powerful shop vacuumm that my daughter like throw Kix cereal over place in Vibe. Took me about fifteen mintues complete clean from front to rear. No more cereal in Vibe for while....
Posted: Sun Apr 24, 2005 1:14 pm
by tnpartsguy
I bought a small vac at Home Depot a few weeks ago, but you can only use it for about 20 minutes at a time. The motor gets so hot that is goes into thermal shutdown! But while it works, it works well....now the Vibe is clean, so it shouldn't need 20 minutes worth of vacumming.
Posted: Thu May 12, 2005 7:43 am
by huskerpt
The best vacuum that I have used is my home vacuum, a Dyson. With three short hair dogs I had to have something better that a Shop Vac or a Hoover Wind Tunnel. I have cleaned both my vehicles with all three vacuums and the Dyson wins hands down. Only downfall it the price, at least $400.
Re: Vacuuming (huskerpt)
Posted: Mon May 16, 2005 12:04 pm
by Stang2Vibe
That reminds me, my mom's Filter Queen vacuum used to do a pretty good job too. But that thing was way too expensive to suggest that someone buy one just for cleaning the car.
Posted: Wed May 18, 2005 12:02 pm
by Atomb
Quote, originally posted by Mr. Poopypants »I have the corded version of that shark vaccuum, it works out much better than battery powered ones. I would recommend the one I have.those corded shark vaccuums suck! sorry, couldn't resist and when i saw that nobody has taken advantage of using the line, i just had to!
Posted: Wed May 18, 2005 12:11 pm
by Ponyota
I'd just buy a small shop vac. Not to small though, I bought a really small one ( Black & Decker) and it isn't very powerful. It hardly even picks up small gravel off the carpet that you get from your shoes. I have to invest in a better one.
Re: Vacuuming (silverawd26)
Posted: Thu May 19, 2005 1:51 am
by Altus
Yup - I'm going to chime in here and vote for good 'ol Shop Vac's too.I've got one of the small ones, a real Shop Vac branded 5 gal one - and it works perfectly - very powerful, and you can get all the attachments you like to work the way you want to.
