Static electricity - anyone getting shocked?
Posted: Sat Apr 16, 2005 11:15 pm
by Hava_Tampa74
I know, weird subject, but I noticed almost everytime I get out of my '05 Vibe and touch the metal on the door to close it, I get one of those static electricity shocks. Does anyone else experience this? Just wondering if maybe I have a short or something. Hopefully, I'm not driving around in a lightning rod, I haven't driven in any electrical storms yet.
Re: Static electricity - anyone getting shocked? (Hava_Tampa74)
Posted: Sat Apr 16, 2005 11:19 pm
by Sputnik
I always get shocks from my cars - all my cars. Must be me. I've got an electric personality.
Posted: Sat Apr 16, 2005 11:21 pm
by Ponyota
Hello and Welcome to Genvibe! I have the same thing happen to me. I'm pretty sure its just like when you wear socks on a carpet and touch something you ground to it and ZAP! You build static electricity up in your body from the seat. When you get out and touch your door or anything else that's metal, the electricity discharges. It's also a good thing to touch metal on the outside of your car to discharge the static electricity before you fill up at the gas station. This has known to cause fires when filling the tank so it's said.
Posted: Sat Apr 16, 2005 11:23 pm
by scherry2
Quote, originally posted by Hava_Tampa74 »almost everytime I get out of my '05 Vibe and touch the metal on the door to close it, I get one of those static electricity shocks. Does anyone else experience this? I have an 03' and it happens all the time. its just your charged personality, thats what i tell myself anyway.
Posted: Sat Apr 16, 2005 11:41 pm
by Hava_Tampa74
Thanks for the replies, at least I'm not alone. I feel better knowing that Vibe owners all over the globe are getting shocked when they get out of their cars.
Re: Static electricity - anyone getting shocked? (silverawd26)
Posted: Sun Apr 17, 2005 1:38 am
by Raven
The Vibe is by far the worst car for shocks that I have ever seen. I get zapped so hard you can hear the crackle. I try to remember to touch the metal with my arm first so it doesn't hurt as much as a finger tip. I'm going to try Static Guard spray. I have noticed that it is worse now than it was in the winter which is opposite of what you would expect.
Posted: Sun Apr 17, 2005 1:44 am
by Mr. Poopypants
Welcome, there is a very easy solution to this, it does not get rid of the static but it will not get you shocked. Hold on to a metal piece of the door before you get out and don't let go until your foot hits the ground. This happened to me all the time. I still forget sometimes to hold on but it does prevent you from getting shocked if you remember.
Posted: Sun Apr 17, 2005 5:09 am
by vibe owner
I agree my '03 Vibe is the worst shocker I have owned. Depends somewhat on what shoes you wear, but my Mazda had a slightly-conductive pad on the door grip that seemed to eliminate most shocks. If anyone finds an easy fix, I'm interested!
Posted: Sun Apr 17, 2005 9:52 am
by cdFxer
Fabric softener in the washer. Really. If I dont use this in the dark loads (the GF always does), we know it. Zzzzzappp!
Re: (cdFxer)
Posted: Sun Apr 17, 2005 10:13 am
by Sputnik
I always use fabric softener. I'm still shocking.
Posted: Sun Apr 17, 2005 10:18 am
by jimincalif
Yes, I don't ever recall getting shocked so much with other cars, especially in dry weather. Sliding on the seat upholstery as you get out, and with all plastic on the door, it is easy to build up quite a charge.Once when I was in Arizona I went to buy gas, as I slid my credit card into the pump, got a bad shock on the pump, I think I killed the processor chip in the pump, got gibberish on the display and it would not work, reset or anything.
Posted: Sun Apr 17, 2005 11:01 am
by POLO
Same for me,no wonder why the vibe is so special,he can electrolyse.Maybe he don't want us to leave them,he want to be drivin for ever.
Posted: Sun Apr 17, 2005 11:34 am
by GMJAP
It's become a habit - touch the door metal with the back of my hand when getting out...
Posted: Sun Apr 17, 2005 11:40 am
by NUBlackshirts
How many of you guys are running low profile tires? Sounds strange but the tires can make a difference. I haven't had this problem with my Vibe. However, my 97 Bonneville came with 225/60-16's from the factory. I upgraded to 245/45-17's and started getting shocked every time I got out of the car. Never had that problem with the old tires. Since then, I have talked to others who have had the same problem when they went to a lower profile tire. It probably also makes a difference as to who makes the tire, what the tire compound is, etc. Just thought I would add my experience with this.
Re: Static electricity - anyone getting shocked? (NUBlackshirts)
Posted: Sun Apr 17, 2005 4:08 pm
by Stang2Vibe
>I don't know, I've had 4 sets of tires on my Vibe already and I still get shocked the same. I've always used the stock 16" size so far. And I always use fabric softner in every load of laundry (dryer sheets--I hate having to wait at the washer to add the liquid for the rinse cycle, I have better things to do than babysit the washer).I've got WeatherTech 100% rubber floormats in my Vibe and that may help a little. I noticed today that the shock I get from my Vibe is far less than the one from my g/f's RSX. The interior plastic seems to generate a lot of static in the Vibe. I can feel it lifting the hair on my forearms when I rest my arm on the window ledge on the driver door or on the center console armrest sometimes. I'll have to try the trick with holding on to the metal of the door until my foot touches the ground. But I think I've had this problem with every car that I've owned.
Re: Static electricity - anyone getting shocked? (Stang2Vibe)
Posted: Sun Apr 17, 2005 11:16 pm
by Pablo1669
I too get shocked almost everytime I step out of my car.
Posted: Sun Apr 17, 2005 11:23 pm
by Mase
Static builds up when your clothes slide across the seat fabric when you get out.Solution:Get a full leather seats including a suede floor and headliner....or you all can save time and money and just TOUGHEN UP
Re: Static electricity - anyone getting shocked? (Mase)
Posted: Mon Apr 18, 2005 12:03 am
by Pablo1669
Quote, originally posted by Mase »...or you all can save time and money and just TOUGHEN UP I kinda like the shock. It wakes me up in the morning when I get to work.
Posted: Mon Apr 18, 2005 12:07 am
by sylvainber
i get some good zingers from my vibe, much more so than i did from my previous cars. It is worse in winter, i got some sparks that hurt even through my winter glovesi read recently that tires can cause static buildup. i have the eagle rsa's. i think the seat fabric is part of the cause though. it is worse in dry weather.i was planning to try static guard... i think it's worth a shot.
Posted: Mon Apr 18, 2005 3:17 am
by Atomb
do those 'anti-static' strips they sell in the check out line at Autopart stores worth it? You know those rubber/metal stip things you attach to the underside of your car an it drags on the ground?i get the nasty shock too...more than any other car. it has come to the point now where i flinch pavlovian whenever i get out of ANY car!
Posted: Mon Apr 18, 2005 4:46 am
welcome to genvibe!I don't get many shocks from the car, but I used to get them very bad at work until they changed the carpet to a less static prone brand.If the VIbe is more static prone than other vehicles, it could be the material in the interior. When I bought my 2003, there were two color choices for the interior, mine is the darker one. Is there any correlation between interior color and static shocking?
Posted: Mon Apr 18, 2005 9:15 am
by steves76
all the time especially in the warmer seasons
Posted: Mon Apr 18, 2005 11:04 pm
by zionzr2
first of all... I dont get zapped too much in my vibe.That statics spray does not smell plesant at all.Allways "ground" yourself before fueling... Static is way worse than celphone use at the pump "MYTHBUSTERS"I had someone tell me once that tire compostion had an effect on static build up. Actually the static not being discharged by the tires so its not till you get out and and have a foot on the ground that you get zapped.
Re: (zionzr2)
Posted: Mon Apr 18, 2005 11:17 pm
by slbpsi63
Damn, I tell my friend about this site after I go with him to purchase his vibe...and what does he do.... he starts a static electricity thread. I am soooo ashamed. LOL!!!! Damit it Nosaj!! YOU'RE Fired.
