Does anyone have XM Roady II in your Vibe?
Posted: Wed Apr 13, 2005 10:50 pm
by DaddyVibeMI
Does anyone have XM Roady II in your Vibe?How and where you mount Roady II at?Picture and step by step would be awesome....I know what I need to do antenna and power source.ThanksDaddyVibeMI
Re: Does anyone have XM Roady II in your Vibe? (DaddyVibeMI)
Posted: Thu Apr 14, 2005 10:14 am
by kcinmi
I know its not a roady, but it would mount the same with a Pro Clip.
Re: Does anyone have XM Roady II in your Vibe? (kcinmi)
Posted: Thu Apr 14, 2005 9:10 pm
by DaddyVibeMI
Where you get from?I found this and was thinking to get PH-Mini 4 from Bracketron.Here is link
http://www.myradiostore.us/mou....html I hope this works...
Posted: Thu Apr 14, 2005 9:27 pm
by tnpartsguy
That's JUST the clip thing, NOT the actual bracket. You'll need to get VSM TY-55-02 from
http://www.pro-fit-intl.com there are pictures on that site to show you what it looks like and how to mount it. If I wasn't late for work, I'd find more for you....like Raging's pics of his SkyFi on that VSM.
Posted: Fri Apr 15, 2005 9:41 am
by jjhendri
Hi Forum Members, I also need help on installation of a XM Roady 2 given as a present. I need any information on how to install on 2003 GT w/6 cd changer can I plug into the Aux on back of radio/cd changer?Step by step instructions would be greatly appreciated. Simply install or do I need professional audio installer?jjhendri
Re: (tnpartsguy)
Posted: Fri Apr 15, 2005 10:42 am
by DaddyVibeMI
Quote, originally posted by tnpartsguy »That's JUST the clip thing, NOT the actual bracket. You'll need to get VSM TY-55-02 from
http://www.pro-fit-intl.com there are pictures on that site to show you what it looks like and how to mount it. If I wasn't late for work, I'd find more for you....like Raging's pics of his SkyFi on that VSM. Gotcha, that one is much better than one I was looking at it. You not too late. I didn't order one yet until we get Vibe(very soon). Thank you very much and you are very helpful.Thank you again.....Quote, originally posted by jjhendri »Hi Forum Members, I also need help on installation of a XM Roady 2 given as a present. I need any information on how to install on 2003 GT w/6 cd changer can I plug into the Aux on back of radio/cd changer?Step by step instructions would be greatly appreciated. Simply install or do I need professional audio installer?jjhendriWelcome to forum!! I have to order special bracket to install. I'm going to use 88.5FM for to listen XM radio, just power and antenna to plug in. I will post picture step by step in two weeks or more and I will do same in XM411 forum wells.
Re: (DaddyVibeMI)
Posted: Sat Apr 16, 2005 6:51 am
by Lecanard
I have a Roady 2 installed on a base vibe o4 .its very clean to instal and only takes about 40 min i will up a how to later
Re: (Lecanard)
Posted: Sat Apr 16, 2005 7:52 am
by Lecanard
msn me at
mssc_@hotmail.com and i could transfer a file as i cant attach because its to big why cant i attach a fileyou can down load the file from herehttp://
www.antonwalker.com/downloads/roady_22.doc
Re: (Lecanard)
Posted: Mon Apr 18, 2005 12:03 pm
by DaddyVibeMI
Quote, originally posted by Lecanard »msn me at
www.antonwalker.com/downloads/roady_22.docThanks man! That is very help tips. If I have problem, i will email you....Thanks!!!
Posted: Mon Apr 18, 2005 12:09 pm
If anyone is looking for a mounting solution...Quote »Used to use this to mount my skyfi long before I moved it to the windshield...You get both the VSM (vehicle specific mount) designed specifically for the Vibe and Matrix, as well as the screw-on swivel mount, which allows you to tilt the unit in any direction for easy viewing.This mounts to the right of the climate controls...Normally retails for over $60 for the combo, I'm hoping to get $45 shipped, the unit is in excellent condition.Pics: Note that the previous picture does not show the swivel mount...
Re: (ragingfish)
Posted: Mon Apr 18, 2005 12:14 pm
by DaddyVibeMI
Quote, originally posted by ragingfish »If anyone is looking for a mounting solution...I'm all set and thank you for offer....
Re: (DaddyVibeMI)
Posted: Tue Apr 19, 2005 2:08 am
by Lecanard
Im glad you could use the how too it was my first one.
Re: (Lecanard)
Posted: Tue Apr 19, 2005 4:41 am
by DaddyVibeMI
Quote, originally posted by Lecanard »Im glad you could use the how too it was my first one. Well it will be challenge to hide antenna wire underneat ceiling. I have to be really careful to do it. I will let you know how turn out. I will try work on after I get out from work today.Peace out!!
Re: (DaddyVibeMI)
Posted: Tue Apr 19, 2005 6:21 am
by Lecanard
just push the ant cable down inside the weather strip and all the panels
Re: (DaddyVibeMI)
Posted: Tue Apr 19, 2005 9:46 am
Quote, originally posted by DaddyVibeMI »I'm all set and thank you for offer....I was directing that to anyone. I wanna sell the freakin thing already.
Re: (ragingfish)
Posted: Tue Apr 19, 2005 8:24 pm
by DaddyVibeMI
Quote, originally posted by ragingfish »I was directing that to anyone. I wanna sell the freakin thing already. I know that... I agree with silverawd, have you try put in for sale/trade section? That is your best place put in there......Thanks
Re: (Lecanard), and install instructions for XM Roady
Posted: Sat May 14, 2005 4:00 am
by jjhendri
Hi Lecanard and others on the forum, I finally had some time to do the install about 2 weeks ago, the install was easy, could not believe. The instructions provided by Lecanard was great. Right now have it sitting in the tray below the cupholder until I decide where I will premanently place it. I'm using FM Modulation but here in S. FL stations are at a premium but it works. Do get some bleed through from stations from time to time but I can live with that.jjhendri
Re: (Lecanard), and install instructions for XM Roady (jjhendri)
Posted: Mon Jun 27, 2005 11:41 am
by huskie26
Ok so I will be putting in an XM Roady 2 later this week and I think that between this thread and this linkhttp://
www.vidrenlabs.com/vibe.htmlI should be good to go. Are there any last minute words of advice that anyone culd possibly give me. Thanks.
Re: (huskie26)
Posted: Sun Jul 17, 2005 3:55 pm
by binary
I routed my antenna under the weather stripping in the LOWER left corner of the hatch. It's invisable unless you're looking for it.Then just ran it under the left part of the car, under the driver's side dash, and to the radio.I had to take the spare out and spent about an hour doing it. In a perfect world - I'd like to run it under the am/fm antenna and then along with the same cable... maybe when I feel the need to pull my headliner!.
