bug deflector
Posted: Sun Apr 10, 2005 9:47 am
by Waxler6942
Where can you find a perfect fit bug deflector/hood protector that installs with clips instead of screws or tape?
Re: bug deflector (Waxler6942)
Posted: Sun Apr 10, 2005 10:09 am
by redlava
Posted: Sun Apr 10, 2005 12:41 pm
by litefoot
I have a Lund Xterminator bug shield on mine.It uses four pieces of heavy plastic tape to protect the paint. Then fourC clamp type clamp that uses a flat end screw, to put pressure on the under side of the hood to hold it on. There are no drilling holes for the screws. I am guessing that what you mean by screws. I have removed it to clean the hood, if you remove the tape you cannot tell it was on.
Posted: Sun Apr 10, 2005 11:34 pm
by Waxler6942
thanks that is exactly what i was looking for i am going to order one soon
Re: bug deflector (litefoot)
Posted: Mon Apr 11, 2005 12:35 am
by 21Rouge
Quote, originally posted by litefoot »It uses four pieces of heavy plastic tape to protect the paint. I have removed it to clean the hood, if you remove the tape you cannot tell it was on. Is the "plastic tape" you are describing (for use on paint) readily available as a separate, simple inexpensive item?
Re: bug deflector (Boxgrover)
Posted: Mon Apr 11, 2005 1:31 am
by litefoot
I not sure, I know it is a 3M product.The speed shop I deal with is closed on Mondays.I'll call them Tuesday to see if it is a common part.I emailed Lund tech support. When I get an answer, I'lllet you know. I think I was lucky, I had two sets of tape in the box when I got it.
Posted: Mon Apr 11, 2005 5:28 am
by 21Rouge
Quote, originally posted by litefoot »I have a Lund Xterminator bug shield on mine.I went to Lund's website. It shows two similar products Carflector™; Stone/Bug Deflector for a 2005 Vibe Part no: 20037 http://ventshade.r-catalog.com...=5727!also there is the Xterminator bug shield Part no: 78554
http://ventshade.r-catalog.com/ymm.aspCan someone explain to me the difference between these two shields?
Posted: Mon Apr 11, 2005 11:12 am
by litefoot
Here is some pictures of my Lund Xterminator bug shield.Hope it give you a better idea about the install
Posted: Mon Apr 11, 2005 2:17 pm
by AKLGT
lund carflector:
Posted: Mon Apr 11, 2005 2:56 pm
by kostby
And the difference between them is .... ?
Re: (kostby)
Posted: Tue Apr 12, 2005 12:50 am
by litefoot
I tried to blowup trbvibe’s pictures to get a better look at the bug shield. It looks like the Xterminator is more body contoured where the Carflector is less contoured. And the Xterminator’s mounting clips go through the top to the bottom. And Carflector’s looks like it mounts from the bottom. I can’t tell if they both use the same kind of fastener. The Xterminator has a straight bottom edge where the Carflector looks like it has a rounder bottom edge. Please correct anything that I am wrong about, trbvibe. Unless the way they are fastened to the hood is different. It comes down to, do you want contoured or the less contoured look.
Posted: Tue Apr 12, 2005 5:57 am
by AKLGT
if you want to use either for what they are actually made for, don't think it's going to help a whole lot. i took mine off after 2 summers worth of chips, window dings, and cracks. imo, it sucked and looked like crap on my vibe. but that's just my opinion.
