Do you have a squeak in you dash?
Posted: Thu Nov 21, 2002 4:30 am
by Shadow Realm
I had a squeak in the instrument cluster and the dealer thought they had fixed it. I had it in 5 times and finally they realized when you put the cluster in there is a clip that has a coverlike piece on it ( you have to reomve it for the squeak to go away) that they thought was supposed to be there. If you have this problem that should remedy the situation!
Re: Do you have a squeak in you dash? (Shadow Realm)
Posted: Thu Nov 21, 2002 4:52 am
by NSimkins
Thanks for the post!There was a post with a solution to this problem a few months ago, including instructions and pictures here:
http://forums.genvibe.com/zerothread?id=396
Re: Do you have a squeak in you dash? (NSimkins)
Posted: Thu Nov 21, 2002 4:57 am
by Shadow Realm
Yet again I have posted too late Thank you for the detailed description on how to fix the problem!
