need cassette deck
Posted: Sun Mar 27, 2005 11:56 pm
by 21Rouge
Into the second week after ordering an '05 Vibe. Last car we got was a 2000 Pontiac Montana. The factory stereo was radio and CD but we wanted a cassette deck also. This was back ordered. So when this setup came in we brought back the Montana and it was swapped. Now 5 years later we are again getting the factory default ie CD and radio. I forgot to inquire of the dealer if it is possible to again get a cassette as well. What do you suggest?
Posted: Mon Mar 28, 2005 12:00 am
by Jahntassa
I don't know all the options for the '05, but I know on the '03-04's it would be hard to just 'swap out' the radio, because they used a different format radio than all the other GMs. Same is probably true, unless they changed a lot between 04 and 05.Like I said, i'm not sure if they offer CD/Cassette on the '05 or not, but you should probably find out before delivery, because it's not something they'll be able to find easily unless there's another '05 on the lot that has it.
Re: need cassette deck (Boxgrover)
Posted: Mon Mar 28, 2005 1:14 am
by GMJAP
The Matrix 03 & 04 came with an option for a CD & cassette - basically the single-CD with a cassette in the "blank" space beneath the preset buttons.They come up on Ebay every now and then, and would be a simple swap with the unit that comes with your 05. You could also poke around the web for parts & salvage dealers, but they'll cost more.
Re: (Jahntassa)
Posted: Mon Mar 28, 2005 1:24 am
by 21Rouge
Quote, originally posted by Jahntassa »Like I said, i'm not sure if they offer CD/Cassette on the '05 or not, but you should probably find out before delivery, because it's not something they'll be able to find easily unless there's another '05 on the lot that has it. I checked the Vibe brochure and it doesnt show a cassette as an option.
Re: (Jahntassa)
Posted: Mon Mar 28, 2005 1:28 am
by 21Rouge
Quote, originally posted by Jahntassa »Like I said, i'm not sure if they offer CD/Cassette on the '05 or not, but you should probably find out before delivery, I just checked the Vibe brochure and a cassette isnt an available option from the factory.
Posted: Mon Mar 28, 2005 1:52 am
by Jahntassa
If they didn't change any of the connectors from 03-04 to 05, you can probably get the CD/Cassette from an 03-04 off ebay and throw it in there..
Re: (Jahntassa)
Posted: Mon Mar 28, 2005 3:13 am
by GMJAP
There aren't any active auctions at the moment, but this is what you want:
http://cgi.ebay.com/ws/eBayISA...=WDVW
Re: (GMJAP)
Posted: Mon Mar 28, 2005 5:47 am
by russ257
http://www.crutchfield.com/S-M...C108Sjust put an aftermarket head unit it 80 bucks from crutchfield. i am sure if you shop around you could find somethign cheaper. it will sound better and be cheaper then a gm unit
Posted: Mon Mar 28, 2005 9:43 pm
I bought a CD/tape headunit from an 03 Matrix off ebay, and it was really simple to swap in for the single CD stock Vibe radio. It has the same look as the stock radio, the colors match, provides all the info/RDS stuff that the stock Vibe radio has, just also has a tape deck. Button is labeled CD/TAPE instead of CD/AUX. Should look like the one in the completed auction that GMJAP posted the link for.As Jahntassa said, the question is if the head unit wiring changed between 03/04 and the 2005 models.
Re: need cassette deck (joatmon)
Posted: Mon Mar 28, 2005 10:51 pm
by GMJAP
Quote, originally posted by joatmon »As Jahntassa said, the question is if the head unit wiring changed between 03/04 and the 2005 models. I put an 04 Matrix 6CD in a family member's 05 with Moon & Tunes and it works & sounds great. So you can rest assured that wiring won't be an issue.
Posted: Mon Mar 28, 2005 11:05 pm
by Jahntassa
If you managed to do that GMJAP, then there should be no problem finding an 03/04 deck and putting it in an 05.
Re: (GMJAP)
Posted: Wed Mar 30, 2005 6:57 am
by tnpartsguy
....I wanted a cassette deck, and was told there wasn't one for a Vibe.... now I find out the 'trix had one.... so I called my salvage yard buddy.....$100 later, I have a AM/FM/CD/Cassette from an '03 'trix on it's way to me......add XM, and I will be able to listen to anything I want, including my old beloved cassettes!!!!
Posted: Fri Dec 02, 2005 10:34 am
http://cgi.ebay.com/ebaymotors...%3AIT Quote »Current bid:US $10.50 Time left: 3 days 17 hours10-day listing, Ends Dec-06-05 11:49:31 PSTStart time: Nov-26-05 11:49:31 PSTHistory:2 bids (US $9.99 starting bid)Item location: WILLIAMSON, GeorgiaUnited StatesShips to: WorldwideShipping costs: US $16.00 -- UPS Ground ...I will ship to: USA and Internationally
Re: need cassette deck (GMJAP)
Posted: Sat Dec 03, 2005 9:30 am
by spoonman
Quote, originally posted by GMJAP »I put an 04 Matrix 6CD in a family member's 05 with Moon & Tunes and it works & sounds great. So you can rest assured that wiring won't be an issue.Ok, So if I find a 6CD Vibe stereo, I should be able to install it in my '04 ok with the Moon and Tunes package right??? I can't remember if the 6CD was an option with the Moon and Tunes...Thanks in advance for helping me with my brain lapse...
Re: need cassette deck (spoonman)
Posted: Sat Dec 03, 2005 12:38 pm
by GMJAP
Quote, originally posted by spoonman »Ok, So if I find a 6CD Vibe stereo, I should be able to install it in my '04 ok with the Moon and Tunes package right??? I can't remember if the 6CD was an option with the Moon and Tunes... Yes, it will work fine.
