				What wheel size?
				Posted: Sat Mar 26, 2005 10:51 am
				by oolunchbox
				I'm looking to lower my vibe 1.75" or so but i also wanted to get my wheels/tires flush with the fender flares.  im wondering how wide i can go with tires before ill get rubbing? hsould i go 225/40/17 or something more like 205 or 215 and just get  spacers?
				Re: What wheel size? (oolunchbox)
				Posted: Sat Mar 26, 2005 11:14 am
				by Raven
				Should go 225/45/17 to stay within 3%. Here's a link to a tire size calculator-
http://www.1010tires.com/TireS...ubmit
				Posted: Sun Mar 27, 2005 12:55 am
				by oolunchbox
				i did check out one and the 225/45/17 and 225/40/17 both seemed ok, im not too concerned about the sidewall so the 45 would be ok i guess, im mostly concerned with getting the wheels/tires flush with the fenders without getting rubbing
				Re:  (oolunchbox)
				Posted: Sun Mar 27, 2005 4:30 am
				by Raven
				They won't rub, MadBill has 275's.
				Posted: Sun Mar 27, 2005 5:19 am
				by oolunchbox
				thanks again for the response but i guess i should have phrased my question differently. here goes: i want my wheels to come flush with the frnder flares, how should i go about doing it ie: what size wheels and tires should i go with (im thinkin 17's) or should i just get whatever wheels i like and get spacers to move them out?
				Re:  (oolunchbox)
				Posted: Sun Mar 27, 2005 10:24 am
				by MadBill
				My 275s are might close, in fact rub slightly on the rear, with 32 mm wheel offset, so a 225 would have (275 -225)/2 = 25 mm(1") more outer clearance. Therefore, depending on how far out you want the wheels and what offsets (or spacers) you can find you could likely go as low as perhaps a plus 25 offset and still have adequate clearance. However, when you start changing offset, it affects front tire scrub radius, steering kickback, wheel bearing loads...
