aveo mp3 player in vibe?
remusrm
Post by remusrm »
can i get the aveo mp3 player hoocked up to my vibe? will it work?
09 MazdaSpeed3 ZOOM-ZOOM
Jahntassa
Post by Jahntassa »
Probably not, no. Two different electronics systems.
kcinmi
Re: (Jahntassa)
Post by kcinmi »
probably could do it like in the old days, where you had to cut wires and find out what went where. LIke Jahntassa said, two different wiring systems, but all radios use 12v, they all have speaker outputs, etc. Just a matter of getting the wires going where they need to go. I dont think the AVEO is a true GM vehicle, just like the Vibe.
God, grant me the serenity to accept the things I can not change,the courage to change the things I can, and the wisdom to know the difference.
Re: (kcinmi)
GM did buy out Daewoo, so I'd suspect J is right on this one, the Aveo is likely a Databus system...There's also the issue of the physical radio is the same size...I don't think all GM radios use DIN 1/2...
Jahntassa
Post by Jahntassa »
The radio is DIN size, and probably doesn't use the Databus system. But, I don't know what connector it would use, or if you'd really get any benefits from it over getting something aftermarket.
