Brakes, springs, anti sway bar avalible.
Posted: Sun Jun 09, 2002 10:02 am
by d_m_kolb
Big Rotor Brake Kit front and rear, Eibach (Sportline) Lowering Springs 1.8 Inch Drop (FR) & 2.2 Inch Drop (RR)Eibach (Pro Kit) Lowering Springs 1.5 Inch Drop (FR) & (RR)Progress Technology Spring Progress Anti-Roll Bar
http://www.optauto.com/webstore/ Type in Matrix in the search box in the top right hand conner. Everything will work for Vibe.
Re: Brakes, springs, anti sway bar avalible. (d_m_kolb)
Posted: Fri Oct 04, 2002 8:03 pm
by cohocarl
Just ordered a Progress rear sway bar, but it's back ordered. Will post when received and installed. On other front drive cars I've had, a rear bar alone makes a nice improvement in handling. I've noticed my Vibe doesn't like alot of cross wind on the X-way, so I hope this may help.
Re: Brakes, springs, anti sway bar avalible. (cohocarl)
Posted: Tue Oct 08, 2002 4:04 am
by J.C.
Why just get a rear when you get a set of front and rear from Hotchkis Tuning...! Designed and engineered to work with and off one another..
Re: Brakes, springs, anti sway bar avalible. (J.C.)
Posted: Tue Oct 08, 2002 6:10 am
by cohocarl
I realize a matched pair of front and rear bars is the way to go, although a rear alone will help.The Progress rear bar is only $105, and the rear bar can be changed in about 10 minutes.The pair of front and rear Hotchkiss is priced around $335, and installing a front bar requires a substantial amount of time to install. Two things I do not have alot of lately.......$$$ and time.
Posted: Thu Oct 10, 2002 3:37 am
by J.C.
The rear bar is an easy install... But what gets me is that how somebody can make just a rear bar to work off off of the stock front..If the manufacturer did not have a rear bar in the first place that means that the front bar is not as agressive as you would think... So making just a rear bar is not helping as much as would of thought...!! When we design and make our own swaybars, we go not only bigger in outer diameters but in inner wall thickness as well..... Making a matched set as we have is much more responsive and provides better handling than just adding "ANYONES REAR BAR" ..... I know it's pricey, but you get what you pay for...And I am very interested in doing a group buy for members of GENVIBE.COM....... Anyone interested can call me at 877-466-7655..... I want you guys to "experience the rush that defines control", with Hotchkis Tuning Suspension...
