HP & MPG gains?
Posted: Thu Mar 03, 2005 6:34 pm
by 666vibe
Just got my vibe yesterday, and wondering if others have experienced both HP and mpg improvements with a CAI and magnaflow. Typically, helping the engine better breathe in and out makes it more efficient and it doesn't have to work as hard.I'm a V8 guy, and on my Trans Am, I had the highway mpg up to 26 just with headers, exhaust, intake and ignition and a chip. (I blew that though by working over the engine for the track.)
Re: HP & MPG gains? (666vibe)
Posted: Thu Mar 03, 2005 10:19 pm
by MoonDogg
Congrats on the new vibe... and to answer your questions.. yes the first week I had my magnaflow exhaust and Injen CAI I noticed alot better HP & MPG on the highway.. but in the city... red light to red light hitting lift.. MPG suffers... buts its worth it to watch peoples faces when you hit lift and fly by them...
Posted: Fri Mar 04, 2005 1:01 am
by nismo
Yeah. The most I have ever gotten on my car was 390 miles to a tank. And that was approximately 36-37 mpg after my mods I have now. So, yeah. It helps if you don't have a lead foot either.Inder
Posted: Fri Mar 04, 2005 1:13 am
by NUBlackshirts
On a similar note, I went through my first tank of fuel with absolutely no highway driving. My mileage dropped from around 26 to 21 MPG. Man, if I could only keep my foot out of it.
Re: HP & MPG gains? (NUBlackshirts)
Posted: Fri Mar 04, 2005 1:49 am
by theangrydwarf1
That's my problem.
Re: HP & MPG gains? (theangrydwarf1)
Posted: Fri Mar 04, 2005 2:06 am
by nismo
That problem is probably in 99% of us here.
Posted: Fri Mar 04, 2005 2:53 am
by ballrub
Here's a link to the article on dyno testing a K&N short ram with a Magnaflow exhaust on my Vibe GT:http://www.speed-society.com/f...rt_2/
Re: HP & MPG gains? (ballrub)
Posted: Fri Mar 04, 2005 8:51 am
by 666vibe
Thanks a lot guys!I assume the 2004 and '05 models are identical, so any 2004 part will also fit my 2005!?? I wanna order some parts now, any thoughts?
Posted: Fri Mar 04, 2005 9:08 am
by Raven
No some '04 parts won't fit an '05. An '04 CAI will not fit an '05. I think the exhaust is the same.
Re: HP & MPG gains? (Sunny)
Posted: Fri Mar 04, 2005 9:24 am
by 666vibe
Great. '05 magnaflow's are out there. Anyone seen any '05 cold air intake kits? I kinda wanted to install both at the same time.
Posted: Fri Mar 04, 2005 10:59 am
by tstatum
I've been looking for a couple of month's and still no luck but if you find one first make sure and post.
Posted: Fri Mar 04, 2005 12:48 pm
by DiveNut
Finally ordered the Injen CAI kit for my 2004 Base Vibe from Ptuning, $194.95 delivered. This is the first performance mod I'm trying and hopefully the install will go smoothly. The first non V-8 vehicle I have owned since my FX16 back in 1987, old gear head in heart. In any case looking forward to making some of the other enhancements you guys & ladies have shared on the forum. I live about 20 minutes from Rt66 Drag Strip in Joliet IL and plan on seeing what the little fella will do this summer! Keep you posted and wish me luck with the CAI!
Re: HP & MPG gains? (DiveNut)
Posted: Fri Mar 04, 2005 11:34 pm
by 666vibe
Autobarn shows they have a K&N short ram (polished only) for the '05 base vibes. I wanted red, but will wait for the Injen.Anyone know why the '04 Injen CAI won't fit a 2005? It appears like it should fit. If it's only small modifications, it might be possible.
Posted: Sat Mar 05, 2005 12:09 am
by Raven
Quote, originally posted by 666vibe »Autobarn shows they have a K&N short ram (polished only) for the '05 base vibes. I wanted red, but will wait for the Injen.Anyone know why the '04 Injen CAI won't fit a 2005? It appears like it should fit. If it's only small modifications, it might be possible. I believe it is because the '05 has drive by wire throttle and not cable operated, so it's a different set-up. Check your engine to see. I heard that some early '05s still had a cable throttle.
Posted: Sat Mar 05, 2005 10:52 am
by BlueCrush
Here is one for the '05 AWD(and I'm assuming theBase as well) from Cosmo Racing. It doesn't say if it is for DBW or DBC:http://www.cosmoracing.com/pro...=1023
Posted: Wed Mar 09, 2005 11:51 am
by DiveNut
Well, the Injen CAI arrived via FedEx from Injen.....Damaged! The mounting flange was actually protruding through the box and bent. Talk about a buzzkill. Had to file a claim with FedEx and appearently Ptuning won't re send another one until the claim is resolved approx. 5-7 days. Though with the price of gas araund here lately, $2.02 Reg, $2.21 Premium, it's probably a good thing.[IMG][/IMG][IMG][/IMG]Can't seem to get pics to post?
Posted: Wed Mar 09, 2005 11:54 am
by DiveNut
"Well, the Injen CAI arrived via FedEx from Injen".....I meant From Ptuning, not Injen."
Posted: Wed Mar 09, 2005 3:08 pm
by Celtic_Curse
Same problem with my lead foot. If you don't gun it alot you should notice better mileage. Me the sound is intoxicating so I mash a lot.
Re: (Celtic_Curse)
Posted: Thu Mar 10, 2005 1:32 am
by 666vibe
So far, brand new 2005, I got 30.3 mpg 1st tank and 27.3 2nd tank. There will be some break-in time, so I hope it gets better.I rec'd my Magnaflow, STB and the CAI is on order (CosmoRacing). So I will track my mileage before and after those mods.The biggest problem I have with the Vibe is that there are so many out there. I just hate having the same car as everyone else. I must personalize it to make it different and mine! The windows are tinted now so that helps a bit.I like the idea of anodizing the roof rails black.
Re: (666vibe)
Posted: Thu Mar 10, 2005 1:34 am
by drunkenmaxx
man, that sucks!! around here i am pretty much the only one!! i have seen only 1 other that has been modded at all, it had a drop and window tint, that's all!
Re: (drunkenvibe)
Posted: Thu Mar 10, 2005 1:41 am
by theangrydwarf1
I have seen a few around these parts, but most seem to be stock. I think I'm the only one around that has modded mine.
Posted: Thu Mar 10, 2005 3:37 am
by GMJAP
What kind of MPG improvements are typical with a CAI?
Re: HP & MPG gains? (GMJAP)
Posted: Thu Mar 10, 2005 6:59 am
by theangrydwarf1
You should see a few mpg increase, I don't know for sure how many though.
Posted: Mon Mar 21, 2005 1:38 am
by remusrm
if i put an exhaust on the car will it increase or decrease the milage? I do not consider a intake since i hate the noise. I am a quite kind of guy. also does 26-28mpg average does sound ok for my ride?
Re: (remusrm)
Posted: Mon Mar 21, 2005 3:40 am
by Raven
Quote, originally posted by remusrm »if i put an exhaust on the car will it increase or decrease the milage? I do not consider a intake since i hate the noise. I am a quite kind of guy. also does 26-28mpg average does sound ok for my ride? A free-flow exhaust system will increase your mileage but there will be an increase in noise also. If you replace the resonator on back, you'll see the best results. For combined mileage those numbers are decent.
Re: (Sunny)
Posted: Tue Mar 22, 2005 10:58 am
by remusrm
where is the resonator? i am considering the exhaust. used to have a focuz intake on my mirage and was damn too loud. not into that, but exhaust is clean...
Re: (remusrm)
Posted: Tue Mar 22, 2005 12:22 pm
by Raven
It's approx. under the rear passenger floor.
