O2 simulator
Posted: Wed Mar 02, 2005 10:51 am
by MoonDogg
My friend sent this to me... I wonder if this might work for the vibe/matrix???
http://www.s2ki.com/forums/ind...29959
Re: O2 simulator (MoonDogg)
Posted: Mon Dec 26, 2005 11:07 am
by 4azdmunky
So has anyone done this yet? My vibe throws CEL after installing the Cosmo CAI. Had the same problem with my satty, caused the first O2 sensor to throw undervolt errors. I have a feeling this may work...hmmm..
Re: O2 simulator (4azdmunky)
Posted: Mon Dec 26, 2005 11:27 am
by Raven
Quote, originally posted by 4azdmunky »So has anyone done this yet? My vibe throws CEL after installing the Cosmo CAI. Had the same problem with my satty, caused the first O2 sensor to throw undervolt errors. I have a feeling this may work...hmmm.. What year and model is your Vibe? I had a Cosmo on my '04 Auto and just put one on my '06 5 speed and never had a CEL. Something must not be hooked up right or you got oil on the MAF sensor. Have you had the CEL code read?
Re: O2 simulator (Sunny)
Posted: Mon Dec 26, 2005 11:35 am
by 4azdmunky
It is a base 05 (DBW), auto, 22K miles.Oil on the MAF, now there might be something there. Obviously dirty hands working under a dirty hood. That is a good idea, I'll have to check that out.I haven’t coded the CEL yet, it comes and goes. The only constant is the amount of drive time. If I drive for more than 20 miles at one time it will turn on. However short trips around town and work dont throw CEL.I assumed it was related to the O2 sensor, given the history I had with my satty after modding the intake.
Posted: Mon Dec 26, 2005 12:05 pm
by damronjr
I got one after installing my CAI b/c I installed the VSV upside down. Make sure the cap is down! It should look upside down.
Re: O2 simulator (damronjr)
Posted: Mon Dec 26, 2005 12:12 pm
by 4azdmunky
Noob question, what is a VSV and where is it?
Posted: Mon Dec 26, 2005 12:21 pm
by damronjr
Quote, originally posted by 4azdmunky »Noob question, what is a VSV and where is it?Haha, expected, I said the same thing! It's a vaccuum switching valve. After the CAI it floats in the engine bay with 2 hoses coming out of it. It has a green cap on the bottom and it used to connect to the stock air box. If you have it cap up, the hoses are switched and it will give you a CEL.
Posted: Mon Dec 26, 2005 12:25 pm
by 4azdmunky
OMFG you serious?Yea, it is just hanging there not secured to anything. I hope it is this simple.
Posted: Mon Dec 26, 2005 12:36 pm
by damronjr
Quote, originally posted by 4azdmunky »OMFG you serious?Yea, it is just hanging there not secured to anything. I hope it is this simple.So is that what it was? If so, problem solved! (I hope!)
Posted: Mon Dec 26, 2005 12:39 pm
by 4azdmunky
not sure, I'm heading down to Pueblo tomorrow (2 hrs each way) so I'll know more tomorrow.I'll post back and let you know.
Posted: Mon Dec 26, 2005 12:40 pm
by damronjr
Quote, originally posted by 4azdmunky »not sure, I'm heading down to Pueblo tomorrow (2 hrs each way) so I'll know more tomorrow.I'll post back and let you know.But was it upside down?
Posted: Mon Dec 26, 2005 12:55 pm
by 4azdmunky
oh, sorryno, but it is lying 45 deg to the right (drivers side)
Posted: Mon Dec 26, 2005 1:00 pm
by damronjr
Quote, originally posted by 4azdmunky »oh, sorryno, but it is lying 45 deg to the right (drivers side)As long as the hoses are connected properly, that's all that matters. Mine were backwards.
Posted: Mon Dec 26, 2005 1:07 pm
by 4azdmunky
I didnt change any of the lines during install. I just went and looked at your cardomain pics and everything looks the same. Did I miss something during the CAI install?
Posted: Mon Dec 26, 2005 1:28 pm
by damronjr
If it looks like or is connected like this it is upside down. That black cap should be on the bottom and the hoses should be opposite.
Posted: Mon Dec 26, 2005 1:54 pm
by 4azdmunky
Mine looks different, however considering the hose layout I would have to say that mine is upside down as well.I'll flip it and see what happens, worse case it wont work.
